nitrous outlet plate compare to NOS plate
Hey guys has anyone seen a inprovement when they changed plates from a NOS plate to a nitrous outlet plate? this would be on a TBI plate design 78mm. Just looking for some feed back. I am shooting 150 shot and it has been with a NOS plate. I have a Nitrous Outlet plate and I will change if there is a benifit. Thanks
At the 150 hp level I personaly do not feel you will see any change switching plates. The plate you have basically has a single nozzle discharge spraying across the intake throat and it seals with a paper gasket.
OUr plate design has 6 nitrous and 6 fuel discharges and due to our design we are able to completely saturate the air intake charge with a well attomozed delivery. OUr plate also uses a O-ring style gasket.
In the higher hp ranges the product design and delivery becomes more critical. At a 150 yes our plate will attomize better but you will never notice the difference.
Save your hard earned money and put it somewhere else.
Dave
Dave
