Need help with going to a Nitrous plate...
Old Nov 1, 2011 | 08:02 PM
wantmore's Avatar
Default Need help with going to a Nitrous plate...
Im new to nitrous and my current system is fairly basic to say the least...
Right now I have a wet NX kit that is a Nozzle setup. The nozzle is in a fernco intake bellow..(laugh it up) Believe it or not it works halfway decent. I dont use the system that much, hence for this setup.
Anyways I was looking to go to a plate system to have better flow and looks and was looking for some advice.
Will this plate work with what I have going right now?
http://www.shop.speedunlimited.com/p...plate-kit.aspx
Old Nov 2, 2011 | 01:29 AM
Nitro Dave's Nitrous Outlet's Avatar
How much are you spraying? You say you are looking for better flow, however the plate you are looking at only has a single nozzle discharge and its mounted up close to the front runners. Also that plate will only flow the same amount as the nx shark nozzle. I do agree it would look better though.
Take a minute and look at the Nitrous Outlet plate comversion. Then do a search here on the forum to see the great results others are having with it. There is not another plate available on the market that can compare to ours.
Dave
Old Nov 2, 2011 | 07:59 AM
tittan1500's Avatar
I have run my single nozzle setup on a 150 shot in my "Fernco" all summer, I read the plugs and the distribution is fine.
I am going to bump to a 175 then a 200 and keep watching the plugs, If the distribution is correct I dont think a plate gives any advantage except for looks
Old Nov 2, 2011 | 09:21 AM
wantmore's Avatar
Thanks for the advice Dave and Tittan... I plan to only run 100-125 shot, but you know nitrous, next thing you know your sprayin' 175+ haha
I will keep researching the subject. Thanks guys.
Old Nov 2, 2011 | 09:35 AM
wantmore's Avatar
Default Dave...
One more thing... Im looking at your website but I dont see just the plate for a stock TB LS1
I see this kit...Nitrous Outlet 98-02 F-body Specific Systems
http://www.nitrousoutlet.com/catalog...=14&section=37
But I dont want the whole kit , just the plate..do you have that??
Old Nov 2, 2011 | 11:00 AM
Yes sir, Here is the link to the plate conversion.
http://www.nitrousoutlet.com/catalog...87&product=996
Dave
Old Nov 2, 2011 | 07:52 PM
SCott5's Avatar
Dave
Does this work with other nitrous kits? I bought my car and it has HSW kit on it, but I dont like it and was looking at starting to switch over to your stuff.
Old Nov 2, 2011 | 10:38 PM
Caribe's Avatar
I run the HSW sudden impact noids with the Nitrousoutlet plate with no problems.
Old Nov 3, 2011 | 06:41 AM
87silverbullet's Avatar
You need to do a little more research buddy. I can assure you a 150 shot in a Nitrous Outlet plate will produce a better ET than a 150 in a nozzle. The distribution is always going to be better from a plate being behind the TB and a plate has more than one exit point unlike a nozzle.
Also, most nozzles don't flow too well above a 150 but try it out and let us know.
Old Nov 3, 2011 | 09:49 PM
Bowtiedford's Avatar
night and day difference on how my NOS nozzle hits and the new Nitrous outlet plate does. 5-7 mph on 125 shot nos, and 100 shot Nitrous Outlet I picked up 10-11 mph
Old Nov 4, 2011 | 02:15 AM
WheelsUp84z's Avatar
i will also agree, that going from a nozzle to a N20 outlet plate, it seemed to run noticably better on anything above 100 shot.
Old Nov 4, 2011 | 10:15 AM
I love reading these results. We try to make sure we are careful to what we claim. So usually we are on the conservative side of things. I see company's make false claims or exaggerated claims all the time and it gets under my skin. I want to make sure we are not like those companies. But there is no arguing real world results coming from you guys!
You guys rock!
Dave
Old Nov 4, 2011 | 10:27 AM
a4ls2goat's Avatar
sorry to thread Jack..
Dave, do you guys make a n2o plate for the ls2?
Old Nov 4, 2011 | 11:17 AM
Yes, would be a 90mm plate kit.
http://nitrousoutlet.com/catalog/pro...3&product=1130
Old Nov 4, 2011 | 11:36 AM
You guys rock!
Dave
Not a problem Dave. I had your 2 stage nozzle setup in my car and it worked flawlessly but I didn't like the way I had to route the hoses so I ordered your 2 stage plate conversion just to clean up the engine bay, not to increase performance, but it did. I ended up picking up a tenth and a half in the quarter. You could even hear the difference when I would test the two stages at the line. The nozzle would hit real good but the plate made it a whole lot more snappier when I purged it into the engine.
Old Nov 4, 2011 | 11:44 AM
I have the 2 stage plate also and cant wait till I hook up the second stage. Might have to rethink my traction
Old Nov 4, 2011 | 02:24 PM
Mr. Hyde's Avatar
Thanks to Dave's plate, I'm needing to have the rear end narrowed to fit more tire!
Old Nov 4, 2011 | 09:11 PM
a4ls2goat's Avatar
Originally Posted by WheelsUp84z
I need just the plate..
