Now nozzle location for dry kit. Single injection
Old Nov 15, 2001 | 08:39 PM
LS1[CHEVY]'s Avatar
Default Now nozzle location for dry kit. Single injection
Is it safe to use the 4.7k OHM resistor when on the bottle? Id like to use that hole in my MTI clear lid for a fan nozzel. Anyone doing this already? Any suggestion ?
[ November 20, 2001: Message edited by: LS1[CHEVY] ]</p>
Old Nov 15, 2001 | 09:23 PM
AZZKICKER's Avatar
Default Re: Now nozzle location for dry kit. Single injection
Chevy:
Fireball can get on here and give you the right resistors, but yes it is OK to run them. I am not exactly sure since I have never run it but maybe brian will get on here and get you squared away!
Old Nov 15, 2001 | 09:36 PM
LS1[CHEVY]'s Avatar
Id appreciate any input. Id hate to drill a hole in my new clear lid .
Old Nov 16, 2001 | 01:55 PM
Patman's Avatar
I would think that with nitrous you'd be better off going with a resistor that makes your computer think the intake air temp is actually hotter, that way it runs a slightly less agressive timing curve, thus keeping your engine a bit safer when on the bottle.
[ November 16, 2001: Message edited by: Patman ]</p>
Old Nov 16, 2001 | 04:34 PM
LS1[CHEVY]'s Avatar
I dont care what resistor I have to use .. I just want to avoid drilling into a brand new lid. Do you think it would be safe?
Old Nov 16, 2001 | 06:29 PM
flyin red TA's Avatar
Do you mean the IAT sensor relocator? I think you're confusing the relocator with the tricker.
What you're saying is you want to spray through the current location of the IAT sensor right? I think the hole might be too big for the nozzle.
Old Nov 16, 2001 | 07:39 PM
LS1[CHEVY]'s Avatar
Yes thats exactly what I want to do . I have a single fan nozzel instead of the 2 nozzels the nos5177 kit came with.
Old Nov 17, 2001 | 01:08 AM
Well I'm sure it's possible...just relocate the IAT sensor, and see if the nozzle will fit in the hole. If the hole is too big maybe you could try something with some washers.
Or you could hide the nozzle and spray through the bottom of the neck of the lid, but you would have to hack up the lower airbox.
Old Nov 17, 2001 | 11:25 AM
LS1[CHEVY]'s Avatar
Well here is where I got the idea , but this guy has a MAFT .
\image{1}
\image{2}
Old Nov 17, 2001 | 11:27 AM
LS1[CHEVY]'s Avatar
Old Nov 19, 2001 | 07:01 PM
LS1[CHEVY]'s Avatar
Has anyone tried using an fernco sleeve between the lid and the MAF then plumbing a dry shot into that ? Would that work so I would not have to drill a hole in my lid??
BTW
This was someones idea I met at the VF meet in PA.
Please tell me this will work <img src="images/icons/smile.gif" border="0">
Old Nov 21, 2001 | 09:05 PM
LS1[CHEVY]'s Avatar
Someone has to have a clue if this will work . Anyone <img src="images/icons/smile.gif" border="0">
