highest stall with NOS????
Old Nov 22, 2001 | 05:29 PM
RyanJ's Avatar
SSU Moderator
Default Re: highest stall with NOS????
the vigi36 would flash pretty high OMO. Of course i have no direct experience with it, i too have the 3200. What does it flash to off the line on the TNT? do you spray off the line? For nitrous id recommend the Pro Yank 3600E. Patrick seemed to like it a lot and it seems to be a fairly good trade off between NA and N2O.
Ryan
Old Nov 22, 2001 | 11:31 PM
Colonel's Avatar
I'd stay with the 3200 for N2O use. If you do change converters get Yanked!
Old Nov 23, 2001 | 12:41 AM
Slow Z28's Avatar
Default highest stall with NOS????
i ahve the vig3200 now, and i got it cause in y mind it was a good everyday convertor, but i realized it was actually a lot tamer than what i thought it was gonna be. so now i have this free upgrade thing <img src="images/icons/smile.gif" border="0"> , and was thinking of getting it upped to the 3600 setting. is this a good combo to be running with a TNT wet kit? any thoughts on any other convertor? i just like the free stall upgrade, but should i go with a yank pro extreme converter for use with the NOS? thanks!
Chris
Old Nov 23, 2001 | 01:33 AM
Slow Z28's Avatar
yeah i spray off the line. worked really good. maybe the vig3600 would be a bit much. but what about a mild built motor? one where the redline would be 6800? guess the yank is looking pretty good right now.
Chris
Old Nov 23, 2001 | 10:19 PM
Silver LS1's Avatar
I suggest if you upgrade to the looser converter you have plenty of traction. The higher stall is going to hit the tires alot HARDER. I leave at 4700 with a stock motor on the spray. <img src="images/icons/shocked.gif" border="0">
Old Nov 24, 2001 | 03:56 AM
Slow Z28's Avatar
traction is not really an issue, well too much. i'm hitting consistent high-1.5's running the NOS with the 3200. the HAL's and skinnies are coming for Christmas. hopefully they'll help out. i want something that's good for N/A runs too. thanks for the help.
chris
Old Nov 28, 2001 | 03:13 PM
Matt98SS's Avatar
I had the 3600 Vigilante and could never get it to hook on ET Streets with nitrous even on the best hooking days. It was just too much, if it hooked it probably would have been a 1.3X but never could <img src="images/icons/smile.gif" border="0"> the 3200 worked much better for me and is bit better top end
Old Nov 28, 2001 | 05:20 PM
2K2 LS1's Avatar
[quote]Originally posted by Colonel:
<strong>I'd stay with the 3200 for N2O use. If you do change converters get Yanked!</strong><hr></blockquote>
I ran the tp 4400 out of your car you sold cmarsh93Z and tried to spray 125 dry <img src="images/icons/rolleyes.gif" border="0"> I gained a couple tenths in the 1/4 mile. I would say it was a little high for spray. <img src="images/icons/smile.gif" border="0">
Brad
12.59@112
02 Artic White M6 Z28
MODS: free mods, lid, cutout, nittos, ripper
previously 2nd fastest stock internal A4 10.89@126 in 2K1 car <img src="images/icons/smile.gif" border="0">
weened from the bottle to all throtle <img src="graemlins/fluffy.gif" border="0" alt="[Fluffy]" />
Old Nov 29, 2001 | 01:36 PM
Patrick G's Avatar
LS1 Tech Administrator
Vig 3200 and Yank ST3500 are about as high of stall as I'd recommend for use with any kind of big shot of N2O. Remember Brooke had lots of problems on the dyno and track with the Vig 3600 and nitrous. On a Vig 3200, a 150 shot will make the stall rise from 3800 to 4400 rpms at launch. A Vig 3600 would rise even further. It would go from 4300 (N/A) to about 5100 or more on the juice. A larger diameter converter like a Pro Yank will have more holding capacity under the "gas", making it a better nitrous converter, but it won't be as quick on motor as a Vig 3200. Your best bet is to keep the Vig 3200 if you want the best of both worlds.
__________________
2013 Corvette Grand Sport A6 LME forged 416, Greg Good ported TFS 255 LS3 heads, 222/242 .629"/.604" 121LSA Pat G blower cam, ARH 1 7/8" headers, ESC Novi 1500 Supercharger w/8 rib direct drive conversion, 747rwhp/709rwtq on 93 octane, 801rwhp/735rwtq on race fuel, 10.1 @ 147.25mph 1/4 mile, 174.7mph Half Mile.
2016 Corvette Z51 M7 Magnuson Heartbeat 2300 supercharger, TSP LT headers, Pat G tuned, 667rwhp, 662rwtq, 191mph TX Mile.
2009.5 Pontiac G8 GT 6.0L, A6, AFR 230v2 heads. 506rwhp/442rwtq. 11.413 @ 121.29mph 1/4 mile, 168.7mph TX Mile
2000 Pewter Ram Air Trans Am M6 heads/cam 508 rwhp/445 rwtq SAE, 183.092 TX Mile
2022 Cadillac Escalade 6.2L A10 S&B CAI, Corsa catback.
2023 Corvette 3LT Z51 soon to be modified.
Custom LSX tuning in person or via email press here.
Old Nov 29, 2001 | 05:36 PM
Slow Z28's Avatar
thanks guys, i'm still trying to decide if i want to go with NOS again after the motor swap and possible turbo. hey, there's a question, since it's also a power adder, would it be wise to stay with the vig3200 if i went with a turbo? thanks again.
Chris
Old Nov 30, 2001 | 12:11 AM
Colonel's Avatar
Yes, it was way too loose for nitrous use (although I did run a 10.89 on a 125 shot with that converter.)
Old Nov 30, 2001 | 09:03 AM
Loco's Avatar
Damn that sucks. I have a TNT kit installed and I was hoping to get good gains with it with my Yank 4500.
[ November 30, 2001: Message edited by: Loco ]</p>
Old Nov 30, 2001 | 11:15 AM
Patrick G's Avatar
Loco,
Just because you have a high stall converter doesn't mean you can't run the N2O, it just means you won't have the best converter for the application. I'd spray the hell out of it and see what happens.
__________________
Old Nov 30, 2001 | 03:35 PM
APU6speed's Avatar
[quote]Originally posted by Patrick G:
<strong>Loco,
Just because you have a high stall converter doesn't mean you can't run the N2O, it just means you won't have the best converter for the application. I'd spray the hell out of it and see what happens.</strong><hr></blockquote>
hell yes <img src="graemlins/burnout.gif" border="0" alt="[Burnout]" /> <img src="graemlins/burnout.gif" border="0" alt="[Burnout]" />
Old Nov 30, 2001 | 04:06 PM
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
[quote]Originally posted by z28kid98:
<strong>
Would it be wise to stay with the vig3200 if i went with a turbo? thanks again.
Chris</strong><hr></blockquote>
I'd install the power adder first and see.
Old Dec 1, 2001 | 09:56 AM
Loco's Avatar
I sprayed last nite and could only manage a 11.8 @ 115 with a TNT 100 shot. I was hoping low-mid 11s. So I think my verter is too high.
It seems it was only spraying in 1st gear. My window switch is set at 3000-6000 rpm.
[ December 01, 2001: Message edited by: Loco ]</p>
Old Dec 3, 2001 | 02:11 PM
Chris Spiess's Avatar
Loco, sounds like you've got too much stall
