Blown Intake and have some Plug Reading Question.......
I have since completed the cooling line mod to help #7 cylinder and upgraded to a 102MM FAST intake and throttlebody along with a new 102mm N2O Nitrous Outlet Plate and 100mm MAF. Obviously I want to avoid a repeat of this situation this year so really plan to be disciplined with reading plugs. This is where I would appreciate some help. From what I have picked up from the site my current understanding is I want the timing mark at or slightly past the bend towards the end of the strap. To close to the base - too hot, too close the the end of the strap - too cold. Fuel ring should show very slightly tan at the base of the plug. Assuming that is correct I need to know the procedure to tune towards this optimum state. For example, if the timing mark looks good but the fuel seems rich would you just take 2 pounds out of the dedicated or would you also need to remove timing. This is where I get confused. If you remove fuel and run leaner (hotter) would it not require less timing to compensate for the increased heat? Alternatively, if you read the plug and the fuel seems lean and the timing mark is OK would you need to add timing if you add fuel (run colder). I'm really looking for a methodical process that I can follow based on what my base reading of the plugs tell me.
I know this is really wordy but I'm hoping to save someone else from having my experience from last year. Appreciate comments from experienced N2O guys! Thanks.
You want the timing mark just on the tip of the electrode.
Get that there and a clean plug then you can play with 1/2* here and there and slightly more or less fuel to find out what your combo really likes.
Call Dave !
http://www.yellowbullet.com/forum/sh...hlight=coolant
we need to do it to ours soon
