check out this plug...
Old May 2, 2012 | 06:33 PM
  #101
Fbodyjunkie06's Avatar
Pull 3 degrees and check the plugs. If there is no timing mark or it is at the tip add it back in a degree at a time until there is a timing mark or until the car slows down.
If it speeds up from the 3 degrees being pulled then you know what it wanted even if the plug shows you have more lead to play with timing wise. A lot of the old nitrous guys will tell you don't chase the timing mark as long as it is in a comfortable region(before the bend).
Old May 3, 2012 | 12:26 AM
  #102
03EBZ06's Avatar
Originally Posted by camscam02
call your local oriellys (used to be Kragen), give them NGK 1049 they are usually $1.70ish and usually stock them in a warehouse in dixon so they should be there next day. Thats what we usually do
roger that. more savings for nitrous.
Old May 3, 2012 | 09:46 AM
  #103
n2ols1cam's Avatar
ok ill play around with it, thanks for your advice.
Old May 3, 2012 | 11:25 AM
  #104
Lean is mean and to run safe while running lean you need to be cautious and lighter handed on your timing and a cold plug.
Your engine will thank you.
Old May 3, 2012 | 12:53 PM
  #105
n2ols1cam's Avatar
thanks man! im going to the track on sunday so im going to try 19 degrees total on 62n 33f jets. it should be around 12.4-12.5 afr and of course im going to read the plugs.
Old May 3, 2012 | 07:37 PM
  #106
That sounds very close to where I think I will end up with my tune-up for my 62n jet.
B8EFS?
I think with the information you have gathered and what you have just said you will do just fine.
Old May 3, 2012 | 10:27 PM
  #107
n2ols1cam's Avatar
B8EFS?
I actually have a B9EFS just to be safe.
Old May 4, 2012 | 06:10 PM
  #108
Sounds good to me!
Old May 11, 2012 | 11:20 AM
  #109
New plug pictures.
62N 38F 20 degrees total timing BR7EF plug gapped at .030 50/50 sunoco 93/110.
Here is what I see. Timing mark on the tip, starting to show good heat on the tip also.
I think the motor will/would run best like this. Although it did take 3 passes on this set of plugs to get this heat and timing mark to show.
AFR was 11.9-12.0.
I was more worried about getting the car to hook than the tune-up yesterday since the plugs looked pretty decent.
Once I get it to hook, I am going to start leaning it out. I'm pretty sure once I lean it out it won't take 3 passes to show enough heat to read the strap. Porcelain was nice and white with a slight light green(fuel color) ring at the base, very very faint.
I'm missing a plug, don't know where it is so here are 7 of them. And for you smartasses those aren't my hands holding the plugs
Last edited by Fbodyjunkie06; May 11, 2012 at 11:26 AM. Reason: I hate photobucket!!!!!!!!!!!!!!!!!
Old May 11, 2012 | 11:38 AM
  #110
10secZ28's Avatar
beautiful hands man......eh hem i mean plugs
Old May 11, 2012 | 11:50 AM
  #111
Yea yea I knew there would be some comments about the nails.
Even my mom knows how to read a nitrous plug!
Old May 11, 2012 | 12:17 PM
  #112
03EBZ06's Avatar
[QUOTE=Fbodyjunkie06;16299771]New plug pictures.
I would have thought a 62/38 mix would be VERY rich too
plugs hard to discern without porcelain view, but still whats up with a check mark by Rachel's name? : )
Old May 11, 2012 | 12:21 PM
  #113
[QUOTE=03EBZ06;16299998]
New plug pictures.
I think that is a co-worker of my mothers and that they went to eat lunch together.
I'm hoping these NGK's are easier to cut open than those ******* autolites.
I'll try a little later.
Old May 27, 2012 | 10:30 PM
  #114
03EBZ06's Avatar
ahhh...more testing. Ok, fuel jet is finally dialed!!!!!!!!!! for the given jetting.
Now, I need to go back out and turn up the spark a little.
stay tuned...
Old May 29, 2012 | 08:02 AM
  #115
ATVracr's Avatar
Still rich but its getting closer.
I'd pull another 1* out when you start leaning it out.
Old May 29, 2012 | 10:36 AM
  #116
Muah?
Old May 29, 2012 | 11:54 AM
  #117
ATVracr's Avatar
Muah?
Pics above are still pretty rich, I can tell you that before you even cut them open.
See black soot(sp) around the ring.... RICH.
So ya you still have a little ways to go on the fuel as you do that the heat on the strap will start to come also.
Take it slow.
Old Jun 5, 2012 | 11:17 PM
  #118
03EBZ06's Avatar
Just noticed something this weekend.
When running N/A the AFR is very flat. Car was pulling easy 10.8s in 90F+ temps. On nitrous it starts around 11.5 AFR and then goes rich (almost linear) towards 6800rpm.
In any case, N2O solenoid has been replaced w/25amp Nitrous Outlet piece.
I think the progressive may have abused it a little and also the one on there was an older style solenoid.
wish me luck for this weekend cuz its testing time again. : )
Old Jun 9, 2012 | 01:41 AM
  #119
03EBZ06's Avatar
removed outdated NX Express solenoid, added Nitrous Outlet Solenoid.
Increased fuel jetting by 2 jet sizes. It wants more fuel. Just ran out of time tonite.
Old Jun 10, 2012 | 07:45 PM
  #120
Take it slow.
Just saw this. Thanks Wayne. After finding out my bottle pressure was way too low due to the broken shitty gauge on a cheap bottle I bought I found out what was making it so rich. I had a damn 82/40 jet combo on 58psi and the plugs still looked rich and I figured that tune-up would be dead on the money. After talking with camscam he ran/runs the same tune up on a 82n with my fuel pressure.
Should I leave it alone tune-up wise (82n/40f 58psi) with the correct(900-950) bottle pressure and see what it does and go from there?
Or would you pull one more degree still and go from there. I'm only at 16* total timing on the 82/40 tune-up and a pretty heavy mix of 110/93 with almost all of it being 110. I may start running it solely on 110 alone. It's 7.00 a gallon and I only use 2-3 gallons a session.
