HOW TO: Make a Timing Retard Box for a Nitrous Oxide system...
With the NOS mini, you don't need a wot switch. Are you saying you want your system to use a WOT switch and pull timing using the traction control? So basically set it up how I have but using the WOT switch instead of the NOS mini? I don't recommend doing that but I suppose it would look something like the image above. I'd run this by the guys at Nitrous Outlet before actually wiring it like this.
