Walbro Inline = Pig Rich N/A
Old Feb 25, 2002 | 09:16 AM
F1's Avatar
F1
Default Walbro Inline = Pig Rich N/A
Well, the thing works great on the bottle but is killing my N/A runs… I can’t get the O2’s under .960 on motor. Even with the air filter out… Has anyone rigged their inline on a switch, or will it restrict the flow of the in-tank?? The car will run with pump in but not turned on, just don’t know how safe it would be..
Dave
Old Feb 25, 2002 | 10:03 AM
CHRISPY's Avatar
Default Re: Walbro Inline = Pig Rich N/A
Where did you mount the pump?
Down by the filter or up by the tank?
Thanks,
Chris
Old Feb 25, 2002 | 11:07 AM
F1's Avatar
F1
[quote]Originally posted by Chris ARE 360:
<strong>Where did you mount the pump?
Thanks,
Chris</strong><hr></blockquote>
About 8-10" before the filter...
Old Feb 25, 2002 | 11:47 AM
cantdrv65's Avatar
Mine does the same thing I have the big NOS inline pump. I've did some testing the other day with the inline disconnected and still had 55psi....Not sure how much the walbro will restrict though.
Old Feb 27, 2002 | 01:43 AM
Ron@Vengeance's Avatar
I just put the Walbro 340 intank on mine. Autotapped for the first time since the install last night. O2s were at .965 and even peaked at .985. I know this is killing me on motor. theres gotta be a way around it.
Old Feb 27, 2002 | 03:17 AM
akw408's Avatar
[quote]Originally posted by Cammin BeaSSt:
<strong>I just put the Walbro 340 intank on mine. Autotapped for the first time since the install last night. O2s were at .965 and even peaked at .985. I know this is killing me on motor. theres gotta be a way around it.</strong><hr></blockquote>
So what is your fuel pressure? Maybe you could try adjusting your fuel pressure regulator?
Old Feb 27, 2002 | 05:25 AM
JimmyKash's Avatar
put the inline pump on a 12v switch/relay
most people hook up inlines with a relay and one of the wires goes to the relay to the in-tank so when that comes on, the inline comes on...
well, take the wire and put it to a switch.
problem solved
Old Mar 4, 2002 | 04:51 AM
Nickn20's Avatar
[quote]Originally posted by JimmyKash:
<strong>put the inline pump on a 12v switch/relay
problem solved</strong><hr></blockquote>
now that is an awesome answer, but wouldnt it still be rich?
[ March 04, 2002: Message edited by: Nickn20 ]</p>
