Home made N2O Stand Alone Fuel Cell
Just make sure you get the correct fuel pump wiring bulkhead that is used with the 340 Stealth.
I would almost make a bet that you won't have to fill that cell up but one time and that's when you get there before your first pass. Even if you do fill it up, it won't be because it's empty, it will be because you're not comfortable enough with it yet to let it go all the way.
What size shot are you spraying?
I have 50# injectors. Plenty for the motor. I set the fuel cell up for high pressure set at 42 psi. The ZEX plate is a perimeter spray pattern and I felt more comfortable with the higher pressure. I have a direct port I need to finish piecing together so I can take advantage of the FJO's 2nd stage.
...and how many passes that fuel system is good for.
Any update on this? I'm wondering if 1 gallon fuel cell will support a whole 10lb bottle on a 100/150 shot.
looks great by the way.
I think with my 1 gallon fuel cell for my direct port kit spraying 250, I went thru 2 or 3 bottles before I added fuel to the cell and it wasn't even empty. It was maybe 3/4 empty. The 1 gallon cell will last for a while longer then you would think.
