Check for properly functioning solenoids
Old May 19, 2012 | 11:39 AM
GasTiresandOil's Avatar
Default Check for properly functioning solenoids
Getting a pair of solenoids that keeps on blowing a fuse and I was wondering how one would check each one to see if they are functioning correctly. I have a feeling one of them is drawing too much current for whatever reason and popping a fuse.
What is the correct way to test each of them? Am I going to be using a multi-meter to check resistance? Amperage? Use a hot wire and ground to see if they click open and shut?
Old May 19, 2012 | 01:57 PM
1BaddLS2's Avatar
Are you running a relay in your circuit ?
Old May 19, 2012 | 05:43 PM
Yes, and we can firm it is good and functional. The in-line fuse continues to blow.
This is how it has been wired in:
https://ls1tech.com/forums/15303966-post5.html
Old May 21, 2012 | 09:05 PM
Nitro Dave's Nitrous Outlet's Avatar
What solenoids are you using? What size is the fuse?
Old May 22, 2012 | 10:39 AM
Nitrous Outlet solenoids and 40 amp fuses on 40/60 relays.
Old May 22, 2012 | 10:59 AM
How many solenoids? What gauge wire on the power and grounds?
Dave
Old May 22, 2012 | 11:10 AM
Two noids, F and N. Have a 12 gauge going to power and ground.
Old May 22, 2012 | 01:19 PM
Hmm. No reason why a 40 amp fuse should be blowing. Something is not right.
To eliminate the solenoids being an issue un-wire them from the system. Run the power and ground from the solenoid straight to the battery and touch them briefly to fire the solenoid.
If you have time call the shop and let Chris go over the system and the programming of the controller with you. You may have a bad controller or a short in the wiring.
Dave
