Which plate for 90mm FAST and NOS
Old Jul 9, 2012 | 01:33 AM
brandonppr's Avatar
Default Which plate for 90mm FAST and NOS
I have a NOS kit that I had on my v6 s10 about 10 years ago. This kit has fuel and N20 solenoids. It came with a fogger set up.
Would the plate be better? If so should I use the NOS brand plate or are others better?
Car is forged 347 LS1 H/C 98 Camaro auto. Plan on 100-150 shot
Old Jul 9, 2012 | 05:21 AM
josh2002-ws6's Avatar
I would go with a plate. Check out Nitrous Outlet, they can hook you up with whatever you need.
Old Jul 9, 2012 | 11:08 AM
Neal@NitrousOutlet's Avatar
Both the plate and the nozzle and definitely can spray a 100-150 no problem but the higher the shot the more the plate will shine in performance. The plate will atomize better than a nozzle will. Usually if someone is looking to do 150+ we recommend a plate. Not that the nozzle cant over 150 but the better option is the plate.
Old Jul 9, 2012 | 11:52 AM
Roger Blackmore's Avatar
X2 for a nitrous outlet plate. Mine worked great.
Old Jul 9, 2012 | 12:16 PM
brandonppr's Avatar
Are the fittings the same size as NOS?
Old Jul 9, 2012 | 12:34 PM
n2ols1cam's Avatar
so does mine! you cant beat their plates.
Old Jul 9, 2012 | 01:14 PM
10secZ28's Avatar
Sure you can their spray bar setups are right on point as well
Nitrous outlet FTW!!!!
Old Jul 9, 2012 | 06:35 PM
vbls's Avatar
NITROUS OUTLET!!!!!!!! no other answer
Old Jul 10, 2012 | 11:15 AM
brandonppr's Avatar
Will my NOS hoses connect to the nitrous outlet plate or do I have to get new lines or adapter?
Old Jul 10, 2012 | 11:41 AM
Smile
Give them a call. They have great costomer service. Both before and after a purchase.
Old Jul 10, 2012 | 02:39 PM
should be standard lines so yes they should work fine .
Old Jul 10, 2012 | 07:12 PM
brandonppr's Avatar
Could you send me the price or give me a link for the plate only? I can't seem to find it on your site. Thanks!
Old Jul 10, 2012 | 07:28 PM
My6speedZ's Avatar
http://nitrousoutlet.com/catalog/pro...87&product=993
You can also check out the Nitrous Express plates.
http://www.nitrousexpress.com/produc...ls.php?id=1635
Old Jul 10, 2012 | 08:08 PM
brandonppr's Avatar
Originally Posted by My6speedZ
Thank you!
Old Jul 11, 2012 | 03:30 PM
Mustang Hat'r 2's Avatar
Is there a cheaper version? I have a full wet kit but 78mm. Almost cheaper to buy a new kit just for the plate and sell my old stuff
Old Jul 11, 2012 | 03:50 PM
I saw that someone already linked some but here is all GM plates
http://www.nitrousoutlet.com/catalog...=35&section=51
