Fuel solenoid stuck?
Old Apr 13, 2002 | 04:55 PM
akw408's Avatar
Default Fuel solenoid stuck?
I have a NX wet kit and I had reason to suspect my fuel solenoid was not opening. I tested it this weekend, basically pulling the hose off the nozzle and then manually connecting a hot wire to the solenoid. The solenoid clicks, but no fuel. There is fuel pressure up to the solenoid, I checked the hose and fittings to make sure I could see "through" them and they are fine. So I'm sure it's the solenoid.
The funny thing is I just had them "tested" by NX before putting them back on and haven't even had one real run with it. So basically, is it possible for the solenoid to "click", but be stuck closed? My experience now has been yes. How should I handle this? Thanks!
Old Apr 13, 2002 | 05:24 PM
BYBYC5's Avatar
*Bad Trader*
Default Re: Fuel solenoid stuck?
there is a small "gasket type" ""thing"" inside there, my n20 noid did this, so open it up and see if it moved and clogged the "outlet" side, i know what im talking about but its hard to explain, maybe somone eles can elaborate for me
Old Apr 13, 2002 | 06:45 PM
Slowhawk's Avatar
LS1Tech Sponsor
Did you test it with the car running?
Old Apr 13, 2002 | 08:18 PM
akw408's Avatar
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by Slowhawk:
<strong>Did you test it with the car running?</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">I tested it with the car moving and when I found a problem, I tested it all in the garage with the motor off. I have a link to when I tested it earlier :
https://ls1tech.com/ubb/cgi-bin/ulti...=000619#000008
akw408's Avatar
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by Grinch:
<strong>there is a small "gasket type" ""thing"" inside there, my n20 noid did this, so open it up and see if it moved and clogged the "outlet" side, i know what im talking about but its hard to explain, maybe somone eles can elaborate for me</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">I'll try to take a look at this.
Old Apr 14, 2002 | 06:47 PM
rich's Avatar
When you disassemble the solenoid take off the jam nut to remove the cover and coil they sell a nut with 2 pins that will go in the holes it sould come with a rebuild kit with the plunger removed ther is a rubber seat (oring looking thing). when you use gas with 10% ethanol added a.k.a. cheap gas it causes the rubber seat to swell up and when the plunger opens the swollen seat stii won't allow fuel to pass through.Rebuild the noid and use good gas. good luck, Rich
Old Apr 16, 2002 | 04:55 AM
akw408's Avatar
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by rich:
<strong>When you disassemble the solenoid take off the jam nut to remove the cover and coil they sell a nut with 2 pins that will go in the holes it sould come with a rebuild kit with the plunger removed ther is a rubber seat (oring looking thing). when you use gas with 10% ethanol added a.k.a. cheap gas it causes the rubber seat to swell up and when the plunger opens the swollen seat stii won't allow fuel to pass through.Rebuild the noid and use good gas. good luck, Rich</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Where do I get a rebuild kit? I haven't had a chance to take the solenoid apart yet, but I'll try to take some pictures when I do.
Old Apr 16, 2002 | 07:23 PM
akw408's Avatar
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by slow:
<strong>nx warranties thier noids for life, not sure where to get the parts to rebuild</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">The funny thing is I just got it back from NX. Haven't even used it once before this problem showed up.
Old Apr 16, 2002 | 10:19 PM
rich's Avatar
I have rebuilt nos solenoids so I don't know if you can get the rebuild kit from nx or if you have to send it in for warranty call their tech line and find out
Old Apr 16, 2002 | 10:54 PM
slow's Avatar
oh, thats 2 bad NX posts today, yours, and somebody who had a $14 cod for his heater back.
Ryan.
Old Apr 17, 2002 | 12:32 AM
slow's Avatar
Old Apr 17, 2002 | 03:27 AM
akw408's Avatar
<strong>oh, thats 2 bad NX posts today, yours, and somebody who had a $14 cod for his heater back.
Ryan.</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">I had a similar experience, I think I was told it was going to cost me $6 to ship my solenoids back to me and then they ended up charging $11 to my credit card. I was like, WTF, but never bothered to really get my $5 back.
Well, I shouldn't give the perception that it's NXs fault until I figure out what's really wrong. But I did take some time today and I figured out that I may be using a completely wrong size fitting. When I sent my solenoids back to NX to have them inspected, I stripped one of my brass fittings. Well, when I replaced that brass fitting, I didn't really pay close attention to every last detail. I looked real closely today and I noticed that there were some definate differences between my new fitting and old fitting. Apart from the obvious difference in the size of the hole, I think even the threading is different. I think I might be screwing my new fitting in so far to the solenoid that the hole is actually getting jammed against metal inside the solenoid and therefore plugged. Sounds crazy, but I think that may actually be happening. I'm going to try to find a new fitting tomorrow.
<img src="http://home.attbi.com/~highwayls1/fittings1.jpg" alt="" />
<img src="http://home.attbi.com/~highwayls1/fittings2.jpg" alt="" />
Here's a picture of them, my old one are on the left, new one is on the right. Can't really see but the threading is actually slightly different on the new one also.
Old Apr 19, 2002 | 02:20 AM
akw408's Avatar
Okay, well, it's official. In one of the most boneheaded moves I've made, I used the wrong fitting and in fact was plugging the hole by screwing it in so tight. After going to a few places to find the right fitting, I put it in and it worked beautifully. So it wasn't the solenoid at all.
Moral of the story is make sure you have the right fittings and test things thoroughly.
Old May 1, 2002 | 05:00 PM
Tuan Le's Avatar
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by akw408:
[/qb]</font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">I had a similar experience, I think I was told it was going to cost me $6 to ship my solenoids back to me and then they ended up charging $11 to my credit card. I was like, WTF, but never bothered to really get my $5 back.
[/QB][/QUOTE]
The did the same thing (charging $14 COD) to me, twice. One was for a bad bottle heater transducer which they had to replace. And the other was to check out my solenoids.
Each time, I specificly asked them whether it is going to cost me anything and the tech told me no. I don't mind paying if they're up front with me about it. Just don't say one thing and then do another. <img border="0" title="" alt="[Mad]" src="gr_images/icons/mad.gif" />
