New NOS plate system=Rough idle??
Old Jul 15, 2012 | 04:37 PM
WonBadZ28's Avatar
Default New NOS plate system=Rough idle??
Just installed a new plate system and now I have a bad idle. Idles under 500.
The LS6 intake I have is brand new so I don't foresee the intake side gaskets being bad. I can hear a bad vacuum leak near the throttle body. The kit included a a paper gasket to put in between the tb and plate and I was wondering if maybe that gasket is whats bad? Does anyone else have any suggestions?
Is this common for plate systems?
Thanks in advance for looking and your help!
Old Jul 15, 2012 | 06:27 PM
calivette805's Avatar
is your intake manifold torqued to specs? if not it will create idle issues . a while back ago i had the nis plate my gasket was ripped and had no issues
Old Jul 15, 2012 | 07:58 PM
Leeroyws6's Avatar
take a can of carb spray and spray where you hear the air leak and it should change the idle when the leak sucks in the carb spray. that should tell you where its leaking.
Old Jul 15, 2012 | 08:33 PM
WonBadZ28's Avatar
yeah i am going to grab some tomorrow and try it
Old Jul 16, 2012 | 10:28 AM
ShiznityZ28's Avatar
you can also blow smoke at it and you will see the smoke suck in...
Old Jul 16, 2012 | 11:28 AM
Neal@NitrousOutlet's Avatar
yeah it sounds like a leak at the plate to manifold. Are your hoses hooked up or the ends capped off?? If not it could be pulling air in at the jet fittings.
Old Jul 16, 2012 | 11:47 AM
WonBadZ28's Avatar
Yeah all the hoses, wires, connections were all tripled checked.
I will try the carb cleaner tonight.
Now if it is the gaskets by the tb, are their alternative gaskets?
Old Jul 16, 2012 | 10:12 PM
WonBadZ28's Avatar
Issue resolved...thanks guys....stupid paper gaskets!
Old Jul 16, 2012 | 11:46 PM
did you get another or just runing it without one
Old Jul 16, 2012 | 11:56 PM
WonBadZ28's Avatar
Got a new one. Thank god my buddy had a new one.
