Stock fuel pump/injectors not holding up with 100 shot?
I have full bolt-on's and a 100 shot and I was wondering if I am needing a better pump and injectors? Seems like i shuld get a little better gains with the shot than I am. So does stock pump and injectors usually need upgraded withe the 100 shot? I'm going to be upgrading soon anyways because im uping too a 150 shot and adding a baby cam, but im curious to see if im running out of fuel now?
Im running stock pump and injectors on 175 wet shot, and have no problem. I couldnt tell much of a difference from stock to 100 shot. You may want to check your fuel pressure to see if your pump is supplying enough fuel when the nitrous is hitting. Im sure some experts will chime in and help ya out.
On a wet shot you really don't need injectors. That's why its a wet shot. Upgraded pump to me is a must now. I used to run decent shots on stock pumps and realize I had those cars on a ticking time bomb. When was the last time you changed your fuel filter?
When do you spray? Out the hole? 20 feet out? 50 feet out?
Even with a cam you won't need injectors, just the pump with a hotwire kit.
Spraying from a 50 roll isn't really going to give you a seat of the pants feel. Hitting it from out of the hole is where you are going to feel it. Hey that trans might last longer than you think. We ran 10.50's on our for awhile before it let go.
Where did he put the timing then? I don't recommend doing this but i have had cars with 28* of timing in them and pulled 4* and ended up putting all 4 back in so no timing taken out at all on a 100 shot. I wouldn't recommend for you to do that but it is possible you are leaving alot on the table with your timing and your fueling.
