Proton kit BY NX
Old Jul 16, 2012 | 03:05 PM
GMtechmatt's Avatar
Default Proton kit BY NX
i was told they may be back in stock this weeke when i called NX this morning Has anyone used this Kit yet on there Ls1 if so how you like it ?
Old Jul 16, 2012 | 05:03 PM
calivette805's Avatar
they work fine sold mine a while back alot of videos on youtube on how simple the install is
Old Aug 14, 2012 | 03:09 PM
NitrousExpress's Avatar
Ls1tech & Truck Sponsor
Well Matt did you get your proton installed?
Trey
Old Aug 14, 2012 | 03:12 PM
banker099's Avatar
I run one on my 408 in my truck, works perfect! Very simple to install as well.
Old Aug 16, 2012 | 01:30 AM
BottleBoy1's Avatar
Have installed a couple of them in the past. Work good for the smaller shots (150 or less).
For the $ I would say it can't be beat. Specially if you are installing it yourself. If you plan to run the 150 jets & use it on a regular basis if $ allowing I Would upgrade to a 15lb bottle as it will last you Much longer before needing filled.
Old Aug 16, 2012 | 09:11 AM
rmata's Avatar
Similar to a zex NMU. Simple, easy to install, clean setup, and a great beginner nitrous kit. Perfect for someone who doesn't plan on spraying too big a shot.
Old Aug 16, 2012 | 11:41 AM
Yes that is what they were intended for is all the guys that want a simple nitrous system that didn't want to shoot over 150hp. However we have redesigned the proton plus systems to be able to flow up to 250 hp now along with being able to work with a progressive controller.
Trey
Old Mar 22, 2020 | 05:33 PM
MurderedOutSS's Avatar
Default 250 shot max ?
What do I need to spray 200-250?
