No relay
Ok is thier any down side to not running a relay I wired the wot to the noid and use my window switch as a ground interrupter so I won't spray below 3000 rpm or hit my red line
An electrical short is where current flows from the battery, and then somewhere directly to the body chassis or metal which is a direct ground and full unchecked amperage. Since current flows from the battery then direct to ground, it has taken a "short" cut to ground thus creating an electrical "short circuit".
If a wire is shorting to ground without going through a fuse, it will get extremely hot and burn through if current flows long enough, sometimes taking only a few seconds. If a short exists on a fused circuit, then the fuse gets too hot and quickly melts the element inside, thus breaking the circuit and protecting the wires of that circuit.
Copy and pasted from an electrical website.
