sneaky
Old Aug 7, 2012 | 08:52 PM
2 quick's Avatar
Default sneaky
it was laying around my cousins house he has no use for it now can i use it in my stock lt1 camaro?
Old Aug 7, 2012 | 08:57 PM
babbage1109's Avatar
What are you even talking about?
Old Aug 7, 2012 | 11:58 PM
2 quick's Avatar
lol
http://www.summitracing.com/parts/NO...9NOS/?rtype=10
Old Aug 8, 2012 | 02:08 AM
josh2002-ws6's Avatar
You could use it, but I wouldn't think it would make that big of a difference.
Old Aug 8, 2012 | 09:48 AM
87silverbullet's Avatar
^^^Exactly. I used 6 oz of nitrous just tapping the button on a 300 shot and that bottle only holds 10 so I wouldn't even use it.
Old Aug 8, 2012 | 10:30 AM
custm2500's Avatar
Ph.D. in HUBRIS
It wouldn't hurt to have it on the car. If you street race or run for money at the track then 50 hp could be the differance between cash and a negative in your pocket. It isn't very usefull because you will probably only get 1-2 50 shots for a 1/4 mile. If you aren't racing for money then you will be compleatly waisting your time installing it.
Old Aug 8, 2012 | 12:02 PM
2 quick's Avatar
maybe ill try it once thanks everyone
Old Aug 10, 2012 | 01:05 PM
warriorcustoms's Avatar
Youll get tired of fillin the Little bottle & want more!!! LoL Just save your money & buy a good 10lb bottle system. Maybe 5lb if you wanna "hide" everything
Old Aug 10, 2012 | 04:40 PM
Chris@NitroDaves
Guest
Posts: n/a
One thing you need to check is the jetting before you put it on your application. If it's around 45-55psi on the jetting then you should be able to use it without a problem.
