Nitrous Dont hit hard
Old Aug 25, 2012 | 06:26 PM
98LS1driver's Avatar
Default Nitrous Dont hit hard
Ive been having a delima with my car. The kit i have is a NX kit and it had the shark nozzle. I used it on my gt and with a 125 it hit insanely hard. So i sold the car kept the kit put in on my TA. Timing pulled 4 degrees and 150 shot with a dual stage nitous outlet plate using only 1 stage. With bottle pressure at 1050 fresh bottle, lines purged, jets in correctly the car hits the same as the nozzle did on a 50 shot?!?!?!? I dont understand what keeps it from hitting hard the car went from a 8.33 on motor to a whopping 8.01 first pass on nitrous and sprayin gout the gate it went 7.88 this is on et street 27x11.5x16 the 60ft are almost the EXACT same on and off spray cars not spinning or anything. Anyone that can share some light on this please do thanks. Im thinking of going back to the nozzle to see will that make a difference.
Old Aug 25, 2012 | 07:27 PM
Sales@Tick's Avatar
Try using both stages at the same time.
As in 75 in one, 75 in the other set to come on at the same time.
Old Aug 25, 2012 | 07:48 PM
minytrker's Avatar
What jets do you have in? What timing are your running? What plugs?
Old Aug 26, 2012 | 12:31 PM
got the widebAND on showed car really lean checked noids out fuel not spraying so ill be rebuilding this one and trying again on thursday
Old Aug 26, 2012 | 03:32 PM
blacktransam's Avatar
no fuel, no horsepower.
Old Aug 26, 2012 | 04:24 PM
Just got back from a test hit car hits hard even with only 800 psi but I still have the pause on initial hit what could cause that? Afr is 11.1 all the way across the rpm range any ideas
Old Aug 26, 2012 | 06:11 PM
Troy5061's Avatar
Yea somethings up dude, I just got my nitrous installed and Im only running 100 wet shot and it hits HARD. Blows my 295/35R18s off at 60 mph.
Old Aug 26, 2012 | 08:45 PM
minytrker's Avatar
Without more info no one can help you.
11.1 is rich.
Old Aug 26, 2012 | 09:56 PM
bongva's Avatar
Mine stopped hitting hard too after i went to a smaller fuel jet. Old fuel jet was too big, afr was in the high 10s to low 11s
Old Aug 26, 2012 | 11:45 PM
03EBZ06's Avatar
at 800psi and 11.1, it at least appears its probably rich as hell when you hit it then cleans up. then again, post a plug up for review.
Old Aug 27, 2012 | 08:52 AM
ATVracr's Avatar
Spraying nitrous and no fuel and it didnt explode right away?
Cant be true. LOL !!
Most motors are hurt from being to rich not lean.
Old Aug 27, 2012 | 08:57 AM
87silverbullet's Avatar
Getting your bottle pressure a little higher (900-950) should lean it out. Get the pressure up and run it and get us some pics of plugs.
Old Aug 27, 2012 | 10:32 AM
Neal@NitrousOutlet's Avatar
You could be having a little bit of a lean spike or a rich condition in the beginning of the shot. Do you have a fuel pressure gauge? What are you running fuel system and what kind of mods do you have?
Old Aug 27, 2012 | 10:46 AM
Sales@Tick's Avatar
Get the nitrous pressure up to 900-950 and see how much it cleans the fuel up.
It should lean it out a good bit. See what that does for you and report back.
Old Aug 27, 2012 | 12:58 PM
Stock fuel system only mods long tube headers 3000 stall and 125 shot on tr6 plugs thought about doing br7 s
Old Aug 27, 2012 | 03:34 PM
ATVracr's Avatar
Around here the wrong plugs probably burn up the most ****. LOL !
TR6's TTF!
Old Aug 27, 2012 | 03:45 PM
Chris@NitroDaves
Guest
Posts: n/a
I would switch to the BR7EF's asap because it's a whole lot better of a plug to spray on.
Old Aug 27, 2012 | 07:21 PM
What?? Since when?? LOL
Plugs so white you could write on a chalk board.
Old Aug 27, 2012 | 08:05 PM
Sales@Tick's Avatar
TR6's TTF!
But my cousin's brother's sisters great uncle's nephew uses TR6's in his 1000rwhp corvette I can too then!
Old Aug 28, 2012 | 09:21 AM
Chris@NitroDaves
Guest
Posts: n/a
