Spark plug problem!
Old Sep 9, 2012 | 07:59 PM
97camaro383's Avatar
Default Spark plug problem!
What would cause the plugs to do this? H/C/I ls1 with 150 shot on tr6 plugs
Old Sep 9, 2012 | 08:02 PM
10secZ28's Avatar
WAY to hot of a plug, were these pulled right after a wot pull?
Old Sep 9, 2012 | 08:08 PM
ATwelveSec02Z28's Avatar
YEP plug was way too hot.
Couple things... First get a colder plug, TR6s with a 150shot is a bad idea. Plug couldnt disipate the heat, melted the strap, and cracked the ceramic.
Also go with a plug that is not a projected tip...
Then get yourself a borescope and look down the cylinders that cracked the ceramic. I had that happen once, and the ceramic got between the piston and cylinder wall and scored the wall beyond repair.
Old Sep 9, 2012 | 08:18 PM
No i've been running on these for awhile and had noticed my car was smelling rich lately so i finally decided to change them. I was a little shocked when i pulled them out looking like that. The plugs are laying in the order they cam out. First two being the front of motor.
Old Sep 9, 2012 | 08:21 PM
I put br7efs in when i pulled these out yesterday, car seemed to run alot smoother. I made a couple pulls on it last night and now its missing again, but i wasn't 100% sure i got the #8 plug wire to click when i put it on. I will try to get that checked in the next couple days, hope it didnt f*** anything up, seemed to run good most of the night.
Old Sep 9, 2012 | 08:43 PM
03EBZ06's Avatar
looking at the top left plug, too much timing. How much spark are you running? Time for some 7 heat range NGKs. Close the gap down too --looks like you are 40+
Jetting?
Old Sep 9, 2012 | 08:51 PM
Im not sure what my timing is, the car was tuned before i bought it, but my car has the lingenfelter box on it and when i activate system it pulls 6* of timing. Id have to look up jets again, can remember size but its what dyno tune said was a 150. I just put the br7efs in and gapped them to .035
Old Sep 9, 2012 | 08:57 PM
zracer323's Avatar
Heat is what causes that. Could be too much timing or a plug that is too hot. Definitely run a br7ef, a 6 is too hot for your setup and you really want a non-projected tip plug. How much timing are you running?
Old Sep 9, 2012 | 09:07 PM
10secZ28's Avatar
Op says h/c/i and 150 shot id have a number 8 in that thing at a minimum without knowing more, just me though. Non the less id would not be spraying until you have checked that motor out and its been cleared to go.
Old Sep 9, 2012 | 09:11 PM
03EBZ06's Avatar
sounds good.
I find it hard to believe yanking 6 deg you roasted those plugs like that.
Consider cross checking that your LNC2000 is activating.
Too hard to tell from a post, but I would make sure the ORANGE wire is connected to PIN87 of the nitrous/fuel solenoid relay and consider putting an LED for the YELLOW wire (one side to green wire and other to yellow) to make sure the unit is activated and GREEN is grounded.
Old Sep 9, 2012 | 09:22 PM
Just a little more info on the car
Torquer v3 cam
Prc stage 1 ls6 heads
Had a weiand aluminum intake, but just put a ls6 on it
stock bottom end with arp rod bolts
racetronics fuel pump kit
bosch 36lb injectors
yank 3600ss
Flt lvl 4 4l60e
S60 rear with 3.73 & detroit locker
Full exhaust
Im not sure what the timing is set at, but i will try to figure that out in a couple days.
03EBZ06
Ill try to get the lingenfelter box checked tom. It was all professionally installed by House of Boost in Kansas City so i hope its all setup right.
Old Sep 10, 2012 | 06:59 AM
You really need to do a leakdown test.
That porcelian from plugs #3 and #6 (if in order) went "somewhere". Without a single doubt if you borescope those 2 holes, you have some piston and chamber damage at the minimum. Worst case you scored the cylinder walls, that will eventually lead to ring land failure..
Old Sep 10, 2012 | 05:39 PM
dannyz's Avatar
Yup. Sucks to say this, but I agree.
There is a ''small'' chance the pieces went out the exhaust, but you wont know untill you check it out.
Old Sep 11, 2012 | 05:00 PM
shortdog's Avatar
9 Second Club/Nitrous Mod
Title should be: Wrong plugs = burnt tips and possibly a hurt motor..
Alot of the vendors need to take those damn plugs (for nitrous) off of their website. Also, out of the sticky section here on tech!
After dozens of plug info posted here, it's still hard to understand why people insist on using those plugs.
Old Oct 2, 2012 | 03:22 AM
I drove the car a couple times since i put the br7efs in it and sprayed it twice. I developed a miss and finally got around to pulling plugs again. My #8 plug wire looks like it went to **** and won't snap on the coil like the rest. While i was at it i figued id pull the plugs again. Number 6 burnt the strap again! I think I may leave the spray alone for awhile, and now that i got the plugs out im going to check on cylinder 6 with a borescope.
Cylinder 2 & 4
Cylinder 6 (right) & 8 (left)
Cylinder 1 & 3
Cylinder 5 & 7
Old Oct 2, 2012 | 05:35 AM
#6 is hurt. sure as hell looks like a bunch of oil on it.
Do a leakdown test, it will tell you what you dont want to know. My bet is the cylinder or piston in #6 is damaged, and oil is now getting into the cylinder.
Old Oct 2, 2012 | 09:11 AM
Sales@Tick's Avatar
Here is most likely what happened.
You burnt #6 up with the projected tip plugs due to pre-ignition.
It was hurt after that and most likely got a ring land which let oil into the chamber causing detonation after the fact.
Even after switching to the colder plug you had already hurt it and when you sprayed it this time, oil got into the cylinder and caused detonation which melted the strap again.
These motors can take some abuse when the tune is spot on, but as soon as you get too much heat in the plug or in the piston they break the ring land then all hell breaks loose once you get oil in the chamber.
Old Oct 3, 2012 | 01:38 AM
I got the passenger side head of tonight and found this
Old Oct 3, 2012 | 05:41 AM
BLK02WS6's Avatar
This thread is a testament to N2O+TR6+unknown timing=**** broken...
Old Oct 3, 2012 | 08:13 AM
Sales@Tick's Avatar
Yep there is detonation written all over that piston.
See the edges of the piston where it's all nicked up and chipped away? That's where the oil got past and into the combustion chamber. Before you melted the straps off the TR6's detonation occurred and started to chip away at the piston to the point it turned into pre-ignition which then melted the straps off the plugs.
It's too hot of a plug and it places the strap too far into the combustion chamber and this is what happens.
Even though you might be able to get away with it for a while this will happen one day if you continue to do it.
Kind of like what happened to camscam...he will tell you he got too comfortable with that plug and that tune-up and finally after a long time of using it, it bit him in the ***.
This is why we preach cold non projected tip plugs, low timing and leaner afr's which is much safer than a hot plug, rich afr's and more timing.
It also looks like the piece of exhaust valve that broke hit the piston and took a chunk out of it.
