Considering spraying...
Old Sep 11, 2012 | 11:42 PM
ccdominic's Avatar
Default Considering spraying...
here are my mods...
ls1/t56
- Stock Crank
- Scat Forged Rods
- Probe Forged Flat Top Pistons
- Coated Bearings
- Ported & Polished 241 Heads by SLP
- PRC Gold Spring Kit W/ Titanium Retainers, Seats & Seals
- TSP Chromemoly 7.40” Pushrods
-TSP Custom Grind Camshaft 232/234, 595” / 598” , 114 LSA
- LS6 Intake
- Stock Throttle body and MAF
- MSD Plug Wires
- Oil Catch Can
what do you think i should spray and still keep it reliable?
Old Sep 11, 2012 | 11:54 PM
sweet99ss's Avatar
100 shot is safe with all the right stuff. Remember a kit is gonna cost you right around 1k
Old Sep 11, 2012 | 11:59 PM
sweet99ss's Avatar
Nvm just scene you have forged pistons... I would say a 150-175 shot would be no problem with all the right stuff
Old Sep 12, 2012 | 05:13 AM
josh2002-ws6's Avatar
You could spray a lot more then 150-175 as long as your tune is right and you don't get cheap parts. Your motor should take 200-250 and more if you want.
Old Sep 12, 2012 | 10:42 AM
NitrousExpress's Avatar
Ls1tech & Truck Sponsor
^^^ agreed as long as you start with a conservative tune you should be able to do 250 easily if you wanted.
I would however start with a lower shot and work up to where you want to be.
Trey
Old Sep 12, 2012 | 10:54 AM
Neal@NitrousOutlet's Avatar
Originally Posted by ccdominic
here are my mods...
ls1/t56
- Stock Crank
- Scat Forged Rods
- Coated Bearings
- LS6 Intake
- MSD Plug Wires
- Oil Catch Can
I wouldn't hit that car with 100shot unless you got some modifications to your fuel system. Your fuel system, if stock, is going to be at its upper end already.
Do you have stock pump or have you modified the fuel system any???
Old Sep 12, 2012 | 12:21 PM
ccdominic's Avatar
Walbro 255 Fuel pump
Stainless Fuel lines from engine to connectors under car
Z06 Return Fuel Rail W/Vac FPR
Old Sep 12, 2012 | 12:27 PM
00MaroonZ28's Avatar
You can always run a stand alone. That's what I did instead of messing with the fuel lines and tank.
Old Sep 12, 2012 | 01:02 PM
I agree with the stand alone fuel system for the nitrous. Are you looking to make a certain ET or just looking to go faster? The amount of nitrous you will want to spray all depends on that. But you can be assured that you will end up spraying more and more with time, it is addictive. Figured out your goals and then decide from there what kit you want, I personally will recommend a direct port kit. But if you are not looking to do that much, a single nozzle or plate kit could be your best bet. Figure out what you want and get in contact with one of the vendors on here and they will get you setup with a nice quality nitrous system.
Old Sep 12, 2012 | 07:53 PM
ccdominic's Avatar
i'm at about 415whp right now. considering a 150 shot. nothing to major.
Old Sep 12, 2012 | 07:57 PM
pyro719's Avatar
Spray it! People spray 150-200 shots on stock motors all the time. My last LT1 Car had over 100 bottles threw the 150,000 miles stock bottom end.
Old Sep 12, 2012 | 08:02 PM
ccdominic's Avatar
welp, you guys have twisted my arm lol. 500whp at 2800lbs should make for some fun.
Old Sep 12, 2012 | 11:38 PM
I would go with a plate kit based on that. With the plate kit you have room to add more nitrous down the road if you want and they look much cleaner in my opinion. Your current fuel system should be able to cover the 150 shot. If you go much bigger tho I would look into getting a stand alone fuel cell for the nitrous.
Old Sep 12, 2012 | 11:48 PM
punisherls6's Avatar
Your always safer with 100 shot but I've seen plenty run 150 and be ok I have a 100 shot on mine fun stuff
Old Sep 13, 2012 | 02:55 AM
That 150 will be pretty close for the fuel system. I was scraping the limit with walbro 255 and a 100 shot pulling off the fuel rails on mine and decided to do the stand alone to be on the safe side.
Old Sep 13, 2012 | 10:45 AM
ccdominic's Avatar
hrm, sounds like a 100 shot is what i'm looking for. i'm definitely not looking to push my reliability too much.
Old Sep 13, 2012 | 01:26 PM
tittan1500's Avatar
I have pulled a 200 shot off the stock fuel lines and rails with just a racetronics pump and hot wire.
Once I swap transmissions I will go 250 and I am sure it will handle it
Old Sep 13, 2012 | 01:36 PM
Oh, forgot, I was also on E-85.
Old Sep 13, 2012 | 01:38 PM
Nitro Dave's Nitrous Outlet's Avatar
Like suggested above you are at the limit of needing to upgrade the fuel system. The 255 fuel pump is good for about 450-500 on average. If you add a Hotwire to it it will support more. On average a racetronix system will support about 650 rear wheel hp.
I Can help you figure out what Nitrous system would best fit your needs and budget if you would like the help.
Dave
