2010 camaro ls3 tach signal
im installing nitrous and got it all done just need to find a place to get the rpm signal for the msd window switch . where are u guys getting rpm readins from
Which MSD unit are you using?
I am running the MSD 8969 and solder spliced the MSD signal wire (white) into the purple wire on the #1 coil pack. Set the MSD to cylinder 1 in this configuration.
I had used the MSD GMR, but found the Autometer 9117 to provide a cleaner signal at high rpm. Instructions can be found here: http://www.autometer.com/techinfo_ne...px?pg=1&aid=10
