Dual-stage install finished.....
Old Sep 23, 2012 | 12:45 PM
baezi z06's Avatar
Default Dual-stage install finished.....
Hi guys
just finished my Dual stage install
canīt wait to try it out
Baezi
Old Sep 23, 2012 | 01:54 PM
dreww's Avatar
Nice, nozzle and plate.
what jets on each?
Old Sep 23, 2012 | 01:55 PM
03EBZ06's Avatar
looks like you been busy. I like the added nozzle. Seems like an easy way to get a 2n'd stage in there without buying a new plate. In fact, I like it alot. : )
I think that has to be more efficient than trying to shoot 300hp through the plate, if possible at all.
Old Sep 23, 2012 | 02:12 PM
StangBanger317's Avatar
Looks great, Gets me excited to finish mine
Old Sep 23, 2012 | 03:21 PM
baezi z06's Avatar
what jets on each?
I have a .078N .035F dialed in already on the plate
the plan was to throw a .054N in the nozzle and dial it in to start whith
Yes i think i have more controlle on the LAunch whith two stages exspecially on a 6speed
but i just did a AUTO swappe and i have a high stall +4000 so it will be a battle there in the hooke
still running stock suspension
Baezi
Old Sep 24, 2012 | 11:46 AM
Neal@NitrousOutlet's Avatar
Looking good!!! let us know some results!
Old Jan 30, 2013 | 05:26 PM
baezi z06's Avatar
still waiting for the spring to come so i can try the car out
i just finished installing second bottle to the kit so i have now complete dual standalone stages
canīt wait
Baezi
Old Jan 31, 2013 | 07:40 AM
Somebody09's Avatar
are both fuel solenoids being supplied by your stand-alone?
what's that pump next to your tensioner? for vacuum? anymore pictures or details?
Old Jan 31, 2013 | 09:58 AM
baezi z06's Avatar
yes both fuel solenoids are getting itīs fuel supply from the standalone cell , iīm not taking any from the rails.
Itīs GZ vacuum pump you see there in front of the passenger head pulling the vacuum from the oil cap
i can post more pics later....
thanks
Baezi
Old Jan 31, 2013 | 03:57 PM
baezi z06's Avatar
here are few more pics
here you can see the vacuum pump and the single nozzle system the second stage i installed.
here is the plate kit and here you can see i supply both stages whith the same fuel line from the fuel cell
here is the standalone cell in the old battery location. the cover between the cell and the headers is not on the picture btw. to keep the heat away from the cell.
and the battery is in the trunk.
Baezi
Old Jan 31, 2013 | 08:40 PM
Blackpanther99's Avatar
Very impressive work^ Excited to see some track times??
Old Feb 16, 2013 | 03:27 AM
baezi z06's Avatar
thanks
iīm ordering new plugs now from nitrousoutlet : NGK br10 non-projected i already had bought br 10 plugs but they are projected not gona use them
the infoīs about the NGK 10 cold plugs on the forum in the plug chart threat are not right, or atleast not recomended
Baezi
Old Feb 26, 2013 | 09:02 PM
BOOSTEDcatfish's Avatar
LINES every where. looks good man cant wait to see ur results.
im starting my duel-stage setup in a next few weeks. what stand alone is that? I have the battery one from NO. how well did it fit in there? how did u do the battery? is there a shut off switch? I have a million questions for you.
Old Feb 27, 2013 | 08:35 AM
Somebody09's Avatar
HSW's f-body fuse-box area
https://ls1tech.com/forums/parts-cla...el-system.html
Old Feb 28, 2013 | 10:34 PM
cool thanks.
Old Mar 2, 2013 | 04:16 PM
baezi z06's Avatar
the standalone came from TA just welded ears on the bottom of the tank and used the battery plastic-stand just drilled holes threw it and used 8 or 10mm bolt and it fitted smothly there just like it was made for a vette
and the battery is in trunk passengersside, iīm installing shuttoff switch to the setup.
if you have any question you can pm me
Baezi
Old Mar 7, 2013 | 03:15 PM
baezi z06's Avatar
still modding......
installed 2 cranes and 2 nitrouspressure savety switch on each line whith gauge
Baezi
