Finally got some plugs pulled - help with reading please!
P.S. I'm thinking still a little rich and I should pull another degree and lean it out a little more.....
My assessment is slightly rich and leave timing as is until fuel adjusted.
fwiw - 15 degrees is fine for that level however just to be safe I suggested pulling two.
As carter said take your bottle pressure down to 950, take some fuel psi out of the dedicated(try 1psi first) and 2-3* more timing and see what that gets you. That should get you slightly leaner than you are now. Taking the bottle pressure down to 950 may negate the change in fuel psi, but you'll still be working towards a better tune. If it doesn't get you any leaner try taking another .5psi out and see what that gets you. If that gets you in the AFR ball park and fuel ring ball park you were looking for, judge the heat on the strap and start putting .5-1.0 degree back in it and watch the increments on the slip and the MPH to judge whether or not it likes or wants the timing back in it.
I think you're good on the timing you're running now especially with that fuel, but get the fuel ring cleaned up a little more.
I think it's so funny to see guys saying run it at 11.x AFR and when I ask what their plugs look like they say "perfect". Just looking at your fuel ring with the AFR you are running at goes to show that there is no way in hell 11.x AFR will give you a "perfect" plug reading.
Nice to see everyone sharing data and opinions.
