Race Fuel ?
Old Jun 10, 2002 | 02:15 PM
AlonzoVersion 1.0's Avatar
Default Re: Race Fuel ?
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by ScottyG:
<strong>I'll soon be running a 100hp wet TNT kit on my heads/cam/stock bottom end car.
What race fuel should I be running? Is the leaded fuel O.K. as long as the cats are gone?</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Thats what I said and some of the memebers on here called me crazy but so long as the cats are off then you dont have to worry about it.I have ran 114 leaded before and it didnt hurt a thing actually I have ran it a couple times.They say it might foul out your o2 sensors but it has never happened to me or my buddys twin turbo supra.
Old Jun 10, 2002 | 02:26 PM
BIGBOS's Avatar
Isn't 100 octane enough to support the spraying needs??
Old Jun 10, 2002 | 02:32 PM
T/A Medic's Avatar
if u use leaded fuel expect to buy new O2 sensors... dont use it... 100 Oct is plenty, if u must have more use a booster as well
Old Jun 10, 2002 | 04:12 PM
Fast SS on TNT's Avatar
I run 100 octane and nothing else. I have heard that leaded fuel will mess up an O2 sensor, but have never seen it firsthand. You can get 110 unleaded, I think, but why? 100 works great, and you may not even need that high of an octane. Race gas is a waste of money unless you have some knock with lower octane fuel.
Old Jun 10, 2002 | 04:54 PM
2000 Camaro SS's Avatar
100 is fine for that shot of nitrous.
Old Jun 10, 2002 | 06:06 PM
Gimp98TNT's Avatar
Definatly dont use leaded gas if you do you better have 120 bucks set aside for new O2's
Old Jun 10, 2002 | 08:03 PM
ScottyG's Avatar
Thanks for the replies.
I'll get some unleaded race fuel and add the NX OBDII fuel booster. It'll get diluted with a little 93 octane since I drive to and (hopefully) from the track.
Hoping for some 10's.......
Old Jun 10, 2002 | 10:47 PM
I would not run more than 100 octane either unless your heads are milled some.My o2's still worked plenty good before my tranny went out.
Old Jun 11, 2002 | 12:37 AM
ScottyG's Avatar
Default Race Fuel ?
Old Jun 11, 2002 | 07:05 AM
Big Mike's Avatar
Sunoco makes an unleaded 104 octane. I think that would work perfectly. This is what I plan on using when running my 150-200 shot.
Old Jun 11, 2002 | 03:12 PM
The Derek H's Avatar
Hey Scotty
We usually run the 104. I'm about to order 275 gallons for personal use and the shop. I'm at home now and should be running soon <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" /> Motor is supposed to be going in the car again this weekend. Too much octane won't hurt anything and you definitely don't want not enough.
Like many others have said the lead will destroy the 02's. If you've ever replaced them you know they are expensive too <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
