Compression Ratio Question.
I am of the "nitrous likes compression camp".
If this is a street car, I'd cap it at around 12:1 with the reverse cooled heads. If it's a race car, I'd look at 13.5-14:1. <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
- Matt
Keep them coming guys... I need suggestions please. Technical knowledge to support your answers would help too.
The actually question is: What compression ratio do you guys recommend for a 200 Wet Shot of Nitrous? I always hear conflicting stories on If Nitrous likes Compression or Not. I do not want to sacrifice too much CR, I will loose N/A power!
However I do not want to go too high either (more probable detonation,etc)
Also I have not picked out the Cam specs as of yet. It must be Lunati... any suggestions?
Thanks in Advance. <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" />
<small>[ June 11, 2002, 12:21 PM: Message edited by: Andy West ]</small>
I dont know what the LT1 can get away with for a streetable compression ratio...but I would build it for best power on motor and then add the shot ontop. you have alot of options for your car for timing controls to retard if necessary...and then can still add race gas if needed. Sounds like running nitrous is a secondary concern to you over running well on motor. I would use a reasonable CR for an LT1 and go from there. I have some good LT1 freinds running 383s and 396 LT1s with decent compression 10:1+ and 200 shots with no problems.
The incredibly low temps of the nitrous intake charge really helps with detonation and allows for aggressive CR.
I am well aware of how nitrous works and how bad too much timing and compression is.
What I am not sure of is.. What is a good compromise on the CR? I do not want it too high. It seems to me 13.5-14:1 might be pushing it.
On the other hand I do not want to loose N/A performance by lowering the CR too low.
Right now I am thinking around 11.5 or 12.1
Does this sound like a good idea?
PS.. I also need help on the cam. I want a nice and hot cam, yet that is still descent for a half way daily driver. So I feel mid-high range torque is of the most importance to me. I also need the cam to work well with Nitrous.....
Any Suggestions on the Cam specs?
*Im not sure if the LT1-LS1 difference will change the cam much or not*
That compression, with our limited number of head bolts/studs, and a decent nitrous set-up = blown head gaskets. OK, use Copper head gaskets, O-ring the heads or block, use head studs, torqued then retorqed after usage, and about 11:1 comp, with a bigger nitrous kit. That will not give you the best HP on nitrous though, as low comp with more N20 is the best. Think of it as a supercharged engine...
Cheers. <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
Any cam suggestions? The only suggestion I have gotten so far (from a friend) is "around 560-580 lift and around 230-245 duration @ .050" <img border="0" title="" alt="[Eek!]" src="gr_eek2.gif" />
How does this sound? <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
Richard
Thanks for the suggestion. <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
<small>[ June 17, 2002, 12:31 AM: Message edited by: Andy West ]</small>
