I've searched...
Old Oct 15, 2012 | 02:23 PM
Cold06's Avatar
Default I've searched...
I've searched but cant find anything even posted in the wiring sticky, I've got a micro wot, fpss, msd 8969 DIGITAL ws, and I'm unsure how to wire it all up. I see this but the 8969 has a grey wire...
Please help, I'm trying to get this installed while I still have a few days off of work.
Old Oct 15, 2012 | 06:51 PM
jblankenship's Avatar
Are you using a zex box
Old Oct 15, 2012 | 06:53 PM
Cold06's Avatar
No just my nx kit and purge. Ive got a paper on how to install that, but the msd 8969 box and fpss.
Old Oct 15, 2012 | 06:54 PM
So just two regular solenoids for a wet kit.
Old Oct 15, 2012 | 06:57 PM
Cold06's Avatar
This is what I got, just need info on where to tie in the msd 8969 box.
Cold06's Avatar
Old Oct 15, 2012 | 07:01 PM
Where the fuel pressure safety switch goes to ground. Instead hook that tithe yellow wire on the msd8969. The window switch will send the ground signal through the fpss. I would also suggest an inline fuse where the black wire hooks to the positive side of the battery.
Old Oct 15, 2012 | 07:04 PM
Cold06's Avatar
Ive got one for that, what about the gray?
Old Oct 15, 2012 | 07:08 PM
The gray on the msd will not be used in your setup.
Old Oct 15, 2012 | 07:21 PM
Cold06's Avatar
Ok so where does everything else go.
Old Oct 15, 2012 | 07:43 PM
What do you mean? Just like the diagram you posted.
