Slower on spray
NA on 100 shot
60 1.94 1.965
1/8 90.66 91.83
1/4 115.03 114.89
ET 12.396 12.391
Engine stock 346 with decent sized nitrous cam 229/237 on 114, LS6 intake, hooker LT and all the supporting suspension etc mods. TR6 plugs, I just pulled them out of the box and installed them. I have about 6 degrees of timing pulled across the board
Kit is a NOS wet plate kit, 100 shot. I had this exact same kit on my old 408TA and it was really nice, blew my trains up I removed it and put it on this car. I have the stock jets for 100 shot.
I checked both solinoids and they are both working(checked with nitrous un hooked but bottle on hard wired) I can feel it hit then drowned out.
Any ideas, blowing the spark out? Jetted wrong(went with what NOS recomends)? Season over but like to fix this bug before I yank the motor out and put a bigger one in.
Thanks
Jay
NA on 100 shot
60 1.94 1.965
1/8 90.66 91.83
1/4 115.03 114.89
ET 12.396 12.391
Thanks
Jay
Also, those are the wrong plugs. The nitrous gurus all recommend BR7s
All the stuff I've read said TR6's its one step colder than a TR55?
BR7's are non projected. Guys say they are safer to run and it makes sense to me. I ran TR6's without issue but switched to BR7's.
Most normal 100 shot tunes are 52n/27f on 55psi.
Try that and report back.
For some larger tunes I would start with these jets:
150-62n/34f@55psi
200-73n/39f@55psi
250-82n/42f@55psi
300-99n/47f@55psi
Can some one tell me where I can find a good jet kit? All the ones I found are singles or you buy sets of 8.
http://inductionsolutions.com/product-category/jets/
Can I only run nitrous outlet jets in there plate? Does the expected jets change now that I have much larger motor set up?
