92 fast plate set up? give me your feed back guys
any of you guys out there have a fast 92/92 set up running any plate set ups...
i really like Nitrous express but the only have a 90mm plate or the 102
i like the nitrous outlet 92 plate set up but i have had friends tell me that the nitous express stuff is just newer and nicer stuff.... im tryn to get a deferent perspective on this other than my local nitrous buddies...
will .079" from the 92 mm intake to the 90 mm plate kit that much of a difference....
and say if I go with the 102 plate kit ( incase i upgrade to a 102 later) will the
.393" ( bigger) difference hurt any in the performance of the kit.
i have a H/C/Bolt-ons LS1 if that matters?
thanks for any advise guys
Do it right without the bottle next of a 90 on a 92.
We have 92 plates and plate systems
http://nitrousoutlet.com/catalog/pro...7&product=3202
Will it work yes...but the issue is you are introducing turbulence to the intake path...large tb opening...smaller plate opening...large intake opening.
research both parts and make your own decision....you are the one that has to live with it.
If you plan on using the 102 intake later make sure to take into account the fact you will need to buy a new plate for that intake.
