heads cam + nitrous help
Old Oct 25, 2012 | 08:00 AM
lsxTAlemy's Avatar
Default heads cam + nitrous help
hey guys its me a again. im running a kit on my brothers car next week. 150 shot the car has patriot performance 5.3 stage 2.5 heads and 228r cam. what u guys recommend for plugs and where do i start with the timing. i thought #7 but want to be on the money here. it's gonna be his first time spraying we will be doing tune by plug. ill be posting pick up next weekend.
thanks go the help so far guys
Old Oct 25, 2012 | 09:39 AM
StrokerTA's Avatar
I would do 8's or 9's.. I like a colder plug then some of the other people on here though. We run 10's in WhiteLTone's car shooting 250.
Old Oct 25, 2012 | 09:43 AM
Sales1@Texas-speed's Avatar
I believe a #7 would work great for you.
Old Oct 27, 2012 | 07:43 AM
lsxTAlemy's Avatar
do i need to know how much timming hes running to know how much to pull ?
Old Oct 29, 2012 | 10:25 AM
lsxTAlemy's Avatar
he has an n/a tune in it now. should i pull 2 degrees per every 50 and the work from there? i haven't been able to find out how much timing the tuner left the car at.
Old Oct 29, 2012 | 11:55 AM
zracer323's Avatar
I would pull 8 degrees to start and work your way up. Better to start with too little timing than too much especially if you don't know what the timing is currently. I would also run a #8 plug.
Old Oct 29, 2012 | 07:40 PM
batboy's Avatar
I'd probably start with a smaller shot like 100 hp at first.
Old Oct 29, 2012 | 08:11 PM
speedtigger's Avatar
Old School Heavy
I started out with 51n jet tune and pulled 7 degrees. After a few test passes, the plugs looked great, so I bumped it to a 55n jet (125hp) and left the timing at -7 degrees. The plugs still look great. A light fuel shadow and a timing mark just above the anode.
Next I will go 59 jet and see how that looks. Then I will go to the 63n jet tune (150 HP). Overly careful? Maybe. But I think I got some great, safe results.
Old Oct 30, 2012 | 07:21 AM
lsxTAlemy's Avatar
thanks guys my plan was to start with 100 go 125 and then 150
