why is my nitrous not activating?
I did check the noids they fire when I hot wire them on the battery so they work. I set my window switch for 1k just so I could push the wot switch with the hose in a cup to see if fuel comes out with it didnt.
Do I need to ground the window switch directly to the negative side of the battery?
Just reread. Your power to the relay should be coming from the battery or the alternator. If you are using power from the TCS circuit you could be overloading it and you may have blow a fuse.
Both my purge and bottle heater work but theyre on separate circuits but they all pull power from the same source.
Since you already tried bypassing the FPSS by connecting the wire from 85 to the yellow from the switch and it still didn't work that should mean it's not the FPSS.
So bypass the W/S now by connecting 85 to a good ground. If your noids do click then your issue is either W/S or the way it's wired.
You really need to run a wire from your battery positive, the stud on the fuse block in the engine bay, or from the stud on your alternator to pin 30 on the relay.
Your fpss is not suppose to have 12v going thru it. The fpss is grounding the circuit. If you werent running the fpss or W/S pin 85 would normally be grounded.
Your solenoids should be receiving power from pin 87. If you wired everything up exactly like the diagram you posted the armin switch gets 12v from whatever source you chose. When you flip the switch it sends 12v to the WOT switch when you depress the WOT switch the 12v will continue thru there and end up at pin 86 which will energize your relay. This will then allow the 12v connected to pin 30 from your battery, or alternator to travel thru pin 87 to your relays assuming your fpss and W/S are connected properly as they are grounding the relay.
