What plug gap?
Old Nov 14, 2012 | 10:29 AM
Chrishbsbll's Avatar
Default What plug gap?
Fixing to run my car on a 200 hit. Just got TR8IX plugs. What gap should I run these to?
Old Nov 14, 2012 | 11:33 AM
Killer5.3's Avatar
We run NGK B8EFS and gapped @ .028 on 200 shot.
Old Nov 14, 2012 | 12:10 PM
Neal@NitrousOutlet's Avatar
What is done with you motor. Compression, etc.
I would get away from those projected TR8IX and go into B8EFS non projected tip plugs.
Old Nov 14, 2012 | 04:47 PM
Tsp 408 10:1.
Why get away from the projected tips?
Old Nov 14, 2012 | 05:49 PM
Carter01's Avatar
They don't dissipate the heat as well as a non-projected tip. many many threads on this topic...
On 200 I usually run .32 or so.
Old Nov 15, 2012 | 05:41 AM
THADD's Avatar
I'm on 9's gap is 26 on a 200 shot.
Old Nov 15, 2012 | 07:59 AM
ATVracr's Avatar
Originally Posted by Chrishbsbll
Tsp 408 10:1.
You can roast marshmallows with a stick (non-projected) or you can hold them in your hand (projected) which one do you think will hurt less?
Old Nov 15, 2012 | 08:29 AM
Burrhos's Avatar
Can you elaborate more on this? Excuse my ignorance, but I would think a projected tip plug would be the 'marshmallow on a stick' analogy. What am I missing?
Old Nov 15, 2012 | 08:56 AM
Tsp 408 10:1.
I stole this picture from another website but look at the difference between a non-projected and projected tip plug. The projected tip plug has the strap further away from the threads over the porcelain. What this does is not allow the heat to dissipate into the threads. This will cause the strap to burn off and damage the motor.
Old Nov 15, 2012 | 09:02 AM
Killer5.3's Avatar
Not being an ***, but, your ignorance is not in not understanding the analogy. It is in not listening to and questioning the professional knowledge of a very respected and knowledgeable sponsor and one of if not the fastest nitrous LS car owner/ tuner/ driver around.
Old Nov 15, 2012 | 09:38 AM
Burrhos's Avatar
I'm not questioning anything and I'm certainly not questioning credentials. I'm trying to understand what he's saying and comprehend the visual representation of the marshmallow to which he is referring.
Old Nov 15, 2012 | 10:39 AM
Killer5.3's Avatar
Well I will try and splain it for you. The non - projected is not representing a stick per se in his analogy. It represents the fact that if you roast a marshmallow with a stick in which your hand would be non- projected towards the fire then the heat will not burn your hand (the plug tip). If you run a projected tip ( or roast the marshmallow holding it in your hand) then you will put your hand close to the fire and burn it or in the case of the plug the projected tip will get hotter and burn it and possibly fall off and into your motor potentially causing damage to said motor. Now do you understand better what he was saying.
Old Nov 15, 2012 | 11:48 AM
ATVracr's Avatar
Didnt mean to confuse you, maybe this will help.
https://ls1tech.com/forums/nitrous-o...tip-plugs.html
Old Nov 15, 2012 | 11:53 AM
Burrhos's Avatar
Great post. Thanks for the link ATV
