Nitrous newbie has a question !
Old Jul 7, 2002 | 11:06 PM
Elite_Hot_Rod's Avatar
Default Nitrous newbie has a question !
I've decided to go with the NX GM EFI kit, GENX2 kit, NX Remote Opener, MSD Window switch and pills. I am planning on using a 100lb shot max(stock lower end). Is there anything else I need to have? I have a stock fuel system also but was told if I only do a 100LB shot I don't need a new fuel pump or bigger injectors. Any help will be appreciated. TIA,
Mark
Old Jul 7, 2002 | 11:15 PM
rich's Avatar
Default Re: Nitrous newbie has a question !
If the genx2 dosen't come with a bottle heater get one and you might want to go with a colder plug like a NGK tr55 or tr6. other wise you have it all covered. Spray your way to victory!!
Old Jul 7, 2002 | 11:23 PM
Bad Habit Bird's Avatar
The GENx2 kit does come with a bottle heater <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
<a href="https://ls1tech.com/ubb/cgi-bin/ultimatebb.cgi?ubb=get_topic;f=10;t=000735" target="_blank">NX kits <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" /> </a>
<small>[ July 07, 2002, 11:23 PM: Message edited by: Bad Habit Bird ]</small>
Old Jul 7, 2002 | 11:56 PM
Thanks guys,
I have TR55's now but I am going to the TR-6's when I switch to the bottle. So, I take it I was informed correctly, I will not need a new fuel pump or bigger injectors for a 100LB shot? TIA,
Mark
Old Jul 7, 2002 | 11:58 PM
Have you dynoed your car recently? It depends on what kind of power your car is making now if you will need a new fuel pump for a 100 shot.
Sean
Old Jul 8, 2002 | 12:20 AM
Sean,
Those dyno #'s in my sig are very recent. They were with the cut out open and the converter locked.
Mark
Old Jul 8, 2002 | 09:35 AM
I would look into getting another fuel pump for the car if you want to spray a 100 shot. Either an inline pump or internal pump would be fine. At your power level (on spray) it isnt required but I definatly recommend it.
If you are planning on spending all this money on a kit why not go ahead and spend the extra $140 for a fuel pump.
Old Jul 8, 2002 | 04:38 PM
rich's Avatar
I have a walbro 340 intank pump for $100 plus shipping it is brand new with the install kit. never installed it. you can email me at rsschuler@netzero.net
