9's first time out..
moser 9 rearend ( shortened 2" per side) w/3.70 gear
built 4l60e
yank 3600 stall
TSP MS3 CAM ( with suporting valve springs)
arp rod bolts
f.a.s.t 90 intake
90mm TB
30LBS INJECTORS
WELD RT-s wheels
and nitrous i'm not sure on
built 4l60e
yank 3600 stall
arp rod bolts
f.a.s.t 90 intake
90mm TB
30LBS INJECTORS
WELD RT-s wheels
+1 on the converter. Ours came with the car is only reason we are running it now. It is getting sent to PTC to get reworked soon when we do gear swap to 3.70 . I would get the MS3 on a 112 0r 113 LSA if you are set on it or custom as Jacob suggested , keep the LS6 intake. Nitrous Outlet 78 mm plate, RPM, FLT, level 7, or Rossler Terminator III trans, custom converter. Spend the $$$ you save on the fast setup for suspension mods. We are swapping to a custom grind suited better for nitrous soon also.
You need to be talking to Greg at FTI. He is like the All Pro of the torque converter world. He keeps his business small enough so he can keep QC tight and produce a top notch product.
http://www.converter.cc/product_p/pas-ls.htm
With that said, I chose Circle D and could not be happier:
https://www.circledspecialties.com
I'd be willing to give any company a shot, however I've never seen anything bad come from PTC. I just need it to be RIGHT from whatever company restalls it.
I work with ATI, Coan, Hughes, and have had real good results with all of them.
Now, that said, you just don't see or at least hear of anyone running one in a fast heads up class like X275, ODR, OL275 or even OL10.5. What you do see in those classes is PTC, Pro Torque, ATI, UCC, Coan, Neil Chance, Bradco, FTI, and Cameron's. You just don't see any Yank converters...in fact the fastest Yank powered car that I know of personally is David Childress' old Mighty Mouse Trans Am and it went 8.49@163 in the 1/4 and 5.40's@130 in the 1/8th. I always wondered what Dave's car would go with a different converter, but it did run damn good.
Btw Martin I think I met some of you guys at an LsX shootout one year. I've been considering getting with you on a camshaft recommendation.
Let me know on the cam, I would be glad to do a grind for you.
Would you be willing to just send me the recommendation? I have a guy who grinds them for me for a good price.
