Unbelievable low numbers on dyno after a wet 150 shot
I have sent my PI 3600 twice and it keeps blowing through the converter. I am going to a different brand on my next converter.
interesting ^^^.. i was also reading some dynos spit out bogus numbers with a high stall? i went out to test her @wot on the street with the bottle on, and she didnt felt strong, kinda bogged on the hit and felt sluggish
![Popcorn](https://ls1tech.com/forums/images/smilies/popcorn.gif)
if the solenoid werent flowing enough it would probably show in the afr if you are using the standard jets.
did you try using fresh plugs for a run and reading them after. it will show you if you are getting poor distribution for some reason.
do you have two widebands or a single? and where is it located?
