How much Nitrous can you run on a Forged bottom end????/
Moderator
![](https://ls1tech.com/forums/images/ranks/ls1tech20year.png)
Just wanting to know what is the Max no2 can be used on a super strength forged bottom end? What kind of fuel also would be be talking about as far as systems??? Stock fuel rails or after market?? <img border="0" title="" alt="[Confused]" src="images/icons/confused.gif" />
LS1 Tech Administrator
Probably a 500 shot. Before you laugh, consider that you'll need to do the following. You'll first need head gaskets and bolts that won't allow the heads to lift under this extreme pressure. Next, you'll need a progressive rpm-based controller that will give you a 150 shot at 3500 rpms, 300 shot by 5000 rpms and 500 shot by 6500 rpms...all at once would kill the motor, IMO. Next, you'll obviously need a dedicated fuel cell with only the best race gas, a dedicated fuel pump w/regulator and a relay activated timing retard system that progressively retards the necessary timing based on rpm level.
Jeff, build the motor right and do these things and a 500 shot is doable. I guarantee you can make a stock short block live under a 300 shot if you do this too. Again, the key is not bringing all the nitrous in at low rpms...gotta treat it more like a supercharger.
__________________
![](https://ls1tech.com/forums/signaturepics/sigpic210_1.gif)
2013 Corvette Grand Sport A6 LME forged 416, Greg Good ported TFS 255 LS3 heads, 222/242 .629"/.604" 121LSA Pat G blower cam, ARH 1 7/8" headers, ESC Novi 1500 Supercharger w/8 rib direct drive conversion, 747rwhp/709rwtq on 93 octane, 801rwhp/735rwtq on race fuel, 10.1 @ 147.25mph 1/4 mile, 174.7mph Half Mile.
2016 Corvette Z51 M7 Magnuson Heartbeat 2300 supercharger, TSP LT headers, Pat G tuned, 667rwhp, 662rwtq, 191mph TX Mile.
2009.5 Pontiac G8 GT 6.0L, A6, AFR 230v2 heads. 506rwhp/442rwtq. 11.413 @ 121.29mph 1/4 mile, 168.7mph TX Mile
2000 Pewter Ram Air Trans Am M6 heads/cam 508 rwhp/445 rwtq SAE, 183.092 TX Mile
2022 Cadillac Escalade 6.2L A10 S&B CAI, Corsa catback.
2023 Corvette 3LT Z51 soon to be modified.
Custom LSX tuning in person or via email press here.
Moderator
What type of system would you consider to do the job, direct port or just a dual stage????retard system? How about re-tuning the pcm to about 20-23 degrees?? <img border="0" title="" alt="[Confused]" src="images/icons/confused.gif" />
Up to 250 shot, single shark nozzle. Over that, direct port. Timing retard is easy. Rewrite the timing tables with LS1 edit. Keep maximum timing for running N/A with IAT temperatures between 30-120 degrees. Any temp over that (120+), you modify the timing tables to run only 20 degrees of timing. When you engage the nitrous it will energize the relay that switches your IAT sensor from reading normal air temps to a resistor value that reads 150 degrees. This will drop your timing to the 20 degrees you programmed in with LS1 Edit...all automatically! <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
Patrick
Patrick
__________________
Since I'm not talking about going to a stand-alone DFI system to control a dry nitrous set-up, my recommendation would be wet. Running a dry 500 shot would take a tremendous amount of computer tuning and injector size/pulsewidth calibrations which are beyond the capability of most mere mortals (including myself).
Patrick
Patrick
__________________
Moderator
Thanks Pat, PM me with your #.
What has already been attempted on a forged stock ci engine in the past????????
Anyone?
Anyone?
BADZ, check your PM.
Patrick
Patrick
__________________
