Progressive controller needed?
Old Jan 13, 2013 | 08:57 PM
PBMGOAT04's Avatar
Default Progressive controller needed?
This past year I used an msd window switch set to spray at 3600rpms on my plate kit. I sprayed a 150 shot all year and it worked fine. This year im changing to a direct port setup spraying 200-250. My question is am I going to have problems using my window switch setup to let it all hit at once at a certain rpm? Do I need to progressively ramp up to that big of a shot?
Old Jan 14, 2013 | 10:05 AM
Neal@NitrousOutlet's Avatar
Honestly depends on traction issues. I wouldn't go spending money on a progressive yet. If you car has the suspension and tires to hook up, you might not have a problem with traction. Now if you are going out to the track and having nothing but problems hooking up then a progressive might be a good option for you. I would get you direct port setup going and start doing some test and tune at the track.
Old Jan 14, 2013 | 07:53 PM
PBMGOAT04's Avatar
Thanks Neal for the info, I was kind of thinking the same myself. I was hoping for this answer
Old Jan 15, 2013 | 09:07 AM
no prob. Save some money and if you need it when you get to that point then look at getting it. No reason to throw money at something you might not need
