Window switch?
Old Aug 5, 2002 | 05:55 PM
rob-ss's Avatar
Default Window switch?
Where do you guys get them? Does anyone have a part#? Just got my NX MAF kit in today but I still need a few more things. Thanks.
Old Aug 5, 2002 | 08:54 PM
2000 Camaro SS's Avatar
Default Re: Window switch?
Darn I know MSD makes one but I can't find it. Thay are called RPM switches also. Someone know what sponsors sell them?
<small>[ August 05, 2002, 08:55 PM: Message edited by: 2000 Camaro SS ]</small>
Old Aug 6, 2002 | 08:24 AM
rob-ss's Avatar
Anyone
Old Aug 6, 2002 | 09:46 AM
383LQ4SS's Avatar
T- Byrne has them on there website. $79 i think.
Old Aug 6, 2002 | 01:09 PM
http://www.tbyrne.com/ls1catalog.html
YUP!
8956 RPM Activated switch $79.99
Old Aug 6, 2002 | 01:51 PM
rob-ss's Avatar
Thanks. The note says you have to send it to MSD for modificaion??? What do they need to do to it? Is there one specifically for our cars that I can just drop in?
<small>[ August 06, 2002, 02:05 PM: Message edited by: rob-ss ]</small>
Old Aug 7, 2002 | 03:57 PM
Z00's Avatar
Z00
Mallory has a switch as well. Doesn't need pills and I have one for sale for $70 + shipping.
<small>[ August 07, 2002, 03:57 PM: Message edited by: Z00 ]</small>
Old Aug 8, 2002 | 09:58 AM
blue1969's Avatar
Also, the MSD-8956 is only capable of switching 1.5 amps. On my wet setup both solenoids draw about 5-6 amps total. So I have to run another relay (it has 10 amp contacts, plenty for the solenoids) between the 8956 and the solenoids. I don't know what the LS1 system solenoid draws but you might want to make sure its not too much.
Jerry
<small>[ August 08, 2002, 10:00 AM: Message edited by: blue1969 ]</small>
Old Aug 9, 2002 | 12:18 AM
slow's Avatar
the NX and TNT kits draw around 20 amps.
All kits come with a relay.
Use the relay supplied, and use the Window switch to supply the ground to the relay, not the noids.
just cut the 2 loops and you will put it in 4 cylinder operation, thats all thats needed to make it work on the ls1.
Ryan.
<small>[ August 08, 2002, 12:20 PM: Message edited by: slow ]</small>
