What size N2o plate should I go with
Im currently looking to swap out my nozzle set up out with a plate, but im not sure which one I should got with. I currently have a fast 102 intake and a 92mm throttle body. Which plate would be recommended for that set up any advice is much appreciated.
a Nitrous Outlet 102 plate worked great and w/my 90mm LS2 TB.
any of them will work, except for the rear facing inlets. i would say 102mm just incase you upgrade your t/b in the future, def wouldnt go with a plate smaller than the port, kinda defeats the purpose of the intake and t/b
our 2010 camaro and g8 90mm plates have side facing inlets.
http://nitrousoutlet.com/catalog/pro...8&product=3923
But if you were buying a new one, might as well buy the correct one.
