Nitrous on an A4 is spray through shifts ok????
#41
Originally Posted by Robert56
You guys watch your tach. don't just say it's this rpm after the shift, but where's it at during shift, that's the area you want to avoid. I used to spray through my stock tranny and it held up (small shot 125hp). You cab also program tranny for quicker shifts. The only reason it takes as long as it does is for comfort. But, this extended slipping for comfort causes undo wear/tear and can get bad fast on the juice. Get a shift kit and/or programing.
My Car during the shift is programmed at 6,500 and my Shift extention is 5,200 rpm's (where it kicks down to after it shifts at 6,500 and then starts climbing again toward the next 6,500 shift point)
The Bandit..............
#42
Import Patrol
I will be running a 150 wet shot, through mine. As you can see in the the sig. I do not have my stock 4L60E anymore, I blew that at the track last year, before iI had the n20. I am getting the 150 next week. Does anyone think that I sould have to worry about my built 4l60e on the 150shot, The trans is rated for 850rwhp. What do you think in here.
