Small shot with my set up?
Old Apr 19, 2013 | 03:45 PM
fly boy_1's Avatar
Sounds like dual pumps is the way to go then. At some point in the distant future I'm planning on running a boosted set up, and possibly ditching the spray. Seems like a good opportunity to beef up the system now. Thanks for all the help from everyone here!
I'll most likely get one of the Nitrous Outlet plate kits once I get the rest of my stuff ready to go. On a 15lb bottle, roughly how many 1/4 mile runs should I expect to get out of a full bottle? Aside from the kit, and a timing puller/window switch are there any other accessories that'd be worth getting that won't come with the kit itself?
Old Apr 19, 2013 | 04:10 PM
brandon@nitrousoutlet's Avatar
The general rule of thumb is that you will use 1 LB of N20 per 10 seconds @100HP. @150 I would say 7-8 passes with good pressure. As far as accessories outside of TPS/Window and timing puller a FPSS is always a good idea. Additionally a bottle heater and purge are things you will want as well. If you plan on going to the track and pass Tech you'll need an NHRA Valve and blow down tube. Feel free to call or PM me if you have any questions or need anything.
Old Apr 19, 2013 | 04:13 PM
HCI2000SS's Avatar
I'm guessing a 15 lb. bottle on a 150 shot might last 6-7 passes maybe. A good bottle heater, nitrous and fuel pressure gauge, and blow down tube would be good to have as well
EDIT: Looks like Nitrous Outlet beat me to it lol
