NOS DRY O2#S ARE SCARY
Old Oct 17, 2002 | 11:45 AM
LASTLS1's Avatar
6 Second Club Moderator
Default NOS DRY O2#S ARE SCARY
I HAVE A 100 SHOT OF DRY CAR IS NEW FUEL PRESSURE IS GOOD, O2'S ARE GOING DOWN TO 795!! I ADDED 8 PERCENT MORE FUEL AND THEY ONLY CAME UP TO 850. ANY THOUGHTS.
Old Oct 17, 2002 | 01:51 PM
BLUEBYU's Avatar
Default Re: NOS DRY O2#S ARE SCARY
Added fuel how? Edit or MAFT? General rule with a dry shot is, if your injector duty is in a safe range NA (60-75%)@ WOT and your A/F is dialed in around 13.0, you do not need to adjust the enrichment for nitrous. The pcm will do it for you! Sounds to me you have a fuel delivery problem....most likely you need to upgrade to SVO 30# injectors. Hope this helps.
<small>[ October 17, 2002, 02:22 PM: Message edited by: BLUEBYU ]</small>
Old Oct 17, 2002 | 01:59 PM
JS's Avatar
JS
Tuning of 02 sensors is BS.Get it on a dyno and see what the REAL a/f looks like via a WB...
JS
Old Oct 17, 2002 | 10:18 PM
LASTLS1's Avatar
added fuel by using a translator. are the scanmaster o2 readings junk? thanks for the input!
Old Oct 17, 2002 | 11:22 PM
Billy C's Avatar
Did you remove your MAF screen ?
Old Oct 18, 2002 | 01:43 PM
LASTLS1's Avatar
screen is still in mass air.
