Cam and 75 shot
My dynotune I'm gonna get? Should I stiffen up my shifts and spray through them or should I get a window switch? Can my stock fuel pump and injectors handle a cam and 75 shot? Reliably? Also what would your shift at?? I have bee hive springs and chrome poly pushrods. Stock ls1 intake! Thanks guys
Then you won't have to worry about pump, injectors and lots of timing being pulled out of your NA tune.
The more you spray the more your NA tune will suffer. When you spray a dry shot you have to add the fuel in your tune. So your NA tune will be missing a few degrees of timing and it will run hella rich. At least with a 30 shot your NA tune won't suffer that much compared to say a 75 shot.
When you're ready for more (with better fueling) just up the shot.
And for a student that I am assuming is going to be relying on the vehicle for daily transportation, it will be more dependable/economical as well
