Spraying on top of heads and cam...
I'm considering a purchase of an NX Wet Kit, genx-2 upgrade kit (bottle warmer, pressure gauge, fuel pressure safety switch, blow down fitting and tube, and purge valve), window switch w/ 3k and 6k pill sets, remote bottle opener, switch panel that goes where the TCS switch is, new plugs, and maybe a couple other things I can't remember right now.
Is there anything I should know about spraying on top of the heads and cam I have? I'm putting down 411 hp right now completely untuned, and still revlimited at 6200 (which should be 6800 now), running extremely rich (11:1 at WOT). I expect to be putting down 425 HP NA and would like to run a 100, or possible a 150 shot.
I'm going to order a new clutch tomorrow. I was debating between the single disk McLeod clutch and the twin disk, but think I've decided on the twin disk setup. Any comments here?
Any general advice/information is more than welcome. Specifically, I'm running a Granatelli MAF, and I'm wondering if that's ok..I've read a couple places where people have said to ONLY use the stock MAF. Does it matter w/a wet kit?
Thanks for your time and advice,
Jonny (Pictures)
You should be fine running a NX 100 shot.A fuel pump would be a good idea for safety.
For extra insurance you could pull timing on the juice with either a Timing tuner or a 1000 ohm resister that takes the place of the Air temp sender (wired on relay)That will pull 2 degrees of timing out.
<strong>I would also upgrade the rear-end if you haven't already. You will need the fuel pump, TR-6 plugs, and get autotap.</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">I'm getting the TR-6 plugs, and I already have autotap. I don't want to spend $3000 on a 12 bolt right now, so I'm not sure what other upgrading I can do. (If I break the rear end, then I'll have no choice, but that's easier to convince the wife of.)
I thought the fuel pump was only needed if I wanted to spray bigger than a 150 shot... or is it actually HP related, and not the size of the nitrous shot?
i am fighting the fuel pump issue now, and my car only made 380 at the wheels with heads and cam on a low compression bottom end with a 100 tnt shot.
if your gonna spray it, be ready to break parts.
good luck with it, its fun when you get it all working!
I do agree with them about the fuel pump. I tried the TNT 75 on the dyno with the stock fuel pump and my fuel pressure dropped to about 40 psi when the kit hit. I bought an ARE modified Walbro 340 intank and its been perfect ever since. Some TR6s or AC Delco FR1LS are also in your future. Good luck and happy hosing <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" />
The only weak points left (I think) are my rear end and drive shaft. But I think I'll take my chances =) Maybe injectors? How would I know if they're causing a problem?
Jonny
