Can you spray through the shifts on an A4!
Old 11-28-2002 | 08:15 AM
Debian Dog's Avatar
Default Re: Can you spray through the shifts on an A4!
I have been spraying through for about 7 months now. Firmed up the shifts and changed shift points.
Old 11-28-2002 | 09:57 PM
Drew778's Avatar
What is everyone setting their shift points and rev limiter at.
Right now with the HPP-3 I have 1-2, 2-3, 3-4 at +2 and the rev limiter at 6300, but this past weekend it hit the rev limiter from 2-3. <img border="0" title="" alt="[Sad]" src="gr_sad.gif" />
Should I raise it to 6400 or 6500?
Also how often to change you tran's fuild?
I just changed it for the first time at 12,200 miles it was a little dark, but didn't smell burn't?
Old 11-28-2002 | 10:03 PM
Ed Blown Vert's Avatar
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by drew778:
<strong>What is everyone setting their shift points and rev limiter at.
I just changed it for the first time at 12,200 miles it was a little dark, but didn't smell burn't?</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">I don't know why anyone would need to raise the rev limiter since N20 make so much torque at lower rpm's
I have mine set at 1-2 -2, 2-3 +1 rev limiter stock with a windows switch set at 5900.
<small>[ November 28, 2002, 09:10 PM: Message edited by: Ed LS1 Vert ]</small>
Old 11-28-2002 | 10:34 PM
Drew778's Avatar
I found it to be the best setting when running n/a?
Plus I'm running street tires, so I can't really use the all the tq. <img border="0" alt="[Burnout]" title="" src="graemlins/burnout.gif" />
<small>[ November 28, 2002, 09:42 PM: Message edited by: drew778 ]</small>
Old 12-02-2002 | 11:42 AM
johnster's Avatar
I spray through shift in my 98 T/A works find.I am syraying 125 dry.Been doing it for about 6 to 8 months.
Old 12-03-2002 | 01:54 AM
Stu'sWS6's Avatar
If your worried about the best possible e.t., which most drag racers are, I would definitely spray through the shifts. If your worried about possibly breaking your 4l60e---don't worry, it IS going to happen sooner or later. Just upgrade to a built unit when it goes. <img border="0" alt="[cheers]" title="" src="graemlins/gr_cheers.gif" />
Old 12-06-2002 | 11:27 PM
jimmyblue's Avatar
Moderator
If it hits the rev limiter, then shouldn't
you be adjusting the shift points downward?
Old 12-22-2002 | 02:25 PM
35th SS's Avatar
spraying through the shift once in awhile 75shot.not hitting rev limiter.no problem here.
Old 12-23-2002 | 11:10 AM
bigoneZ28's Avatar
As jimmyblue asked, shouldn't the shift points be adjusted downwards if hitting rev limiter?
I'm about to install NOS 5177 kit with time based progressive controller. The last thing I would want to do is hit the rev limiter (fuel cutoff?).
I have a TCI3000 Streetfighter and shift points raised +2 and rev limiter at 6500. Any suggestions.
Thanks.
