Suddenly no NO2?
Is there a better way to test it?
The bottle was just filled and it was working before but this started before the last bottle fill.
The best way to look and see if its a solenoid issue or a wiring issue would be to do the following.
1. Unwire the solenoid from the system.
2. Run the positive and ground wires from the solenoid directly to the battery. If you have to extend the wires use at least 12 gauge wire.
3. Hook the ground wire to the battery and during testing you will press the positive wire to the terminal to blast the solenoid.
Most nitrous solenoids are not rated to open over 1100 psi so check your bottle pressure. If the solenoid does not fire and the pressure is below 1100 psi something is probably wrong with the solenoid. Either the coil is breaking down or it has a lot of wear on the piston that changed the seat height. Check with the manufacture to see what the operating specs are.
Dave
Dave
What solenoid would you recommend? I'm only running a 100 shot.
http://www.nitrousoutlet.com/nitrous...-solenoid.html
My favorite choice would be our .125 Nitrous Outlet solenoid. It has a purge port and can support a little under 500 hp.
Dave
