First time nitrous user. And I love it!
Old Aug 12, 2013 | 10:24 PM
SoonerBrad88's Avatar
Default First time nitrous user. And I love it!
After fighting a bunch of stupid problems over the weekend I finally got to make a hit on the bottle yesterday and WOW! That sh*t is a blast.
I'm using a HSW Microedge and I gotta say what an awesome piece of equipment. I'm running a 100 wet shot and pulling 4*. I'm tempted to go bigger but am very nervous as to not damage anything. From all the research I've done if you take the right precautions and don't get greedy you'll be safe.
I used to be very anti spray but figured I'd give it a try and glad I did. So if anyone else is on the fence I'll say at least try it! Also sorry if this post is in thre wrong section.
Old Aug 12, 2013 | 11:22 PM
JDEP162's Avatar
i too recently discovered the joy of spray. and im spraying the 100 shot as well for now, and am tempted to bump to 150 soon. think il enjoy it rest of the season and upgrade fuel sytem over winter. it is a rush, i thought no way a engine cud change so drasticly, but when it hits, bam. any pics of ur setup? im always curious to see others, and not many posts lately detailing build pics
Old Aug 12, 2013 | 11:34 PM
My6speedZ's Avatar
As long as your tune up is safe and your controlling the heat inside the cylinder by using the right plug heat range there is no reason you can't spray a 150.
People have done a lot more on the stock bottom end.
Just read your plugs and you'll fine, if you need help post a picture. I was told to work on getting the AFR right and the timing will sort of work itself out. It will present it'self pretty obviously weather you need to add some. Just remember you can always add a degree and make another pass than screw something up with a ***** to the wall tune up with to much fuel and timing.
Old Aug 13, 2013 | 03:58 AM
I'll try to figure out how to get some good pics up. I'm not real savy when it comes to that stuff. I needed a new pump a few months back and went ahead and put in a Walbro 255 and it seems to be doing the trick
Old Aug 13, 2013 | 04:01 AM
Yeah I went with a TR6 and gapped em to specs I found on here. And I'd like to get a wideband just tl have the extra security but not sure whats the best bang for my buck.
Old Aug 13, 2013 | 04:32 AM
HCI2000SS's Avatar
Yep! A 100 shot is a nice little treat every now and then
Old Aug 13, 2013 | 04:33 AM
My6speedZ's Avatar
NGK AFX, but don't rely solely on a wide band, use that to monitor things during the run maybe but not for your tuning needs. You need to check your plugs because a wideband is going to tell you nothing in the way of how each cylinder is doing. I know your only spraying 100 but best learn how to do it now than trying to learn when the margin of error is much smaller and the cost of getting it wrong is much higher.
Old Aug 13, 2013 | 11:15 AM
That's definitely a good point. Maybe I'll check my plugs after a few bottles of spraying 100
Old Aug 13, 2013 | 12:41 PM
My6speedZ's Avatar
They have to be new, swap them in make, a pass, shut it off on the strip. No idle time...makes them unreadable.
Old Aug 14, 2013 | 06:41 PM
Blackpanther99's Avatar
Sure is fun
Old Aug 15, 2013 | 10:19 AM
Slow LSX's Avatar
Buy HP Tuners, read your plugs and put the 150 jets in and bust some ***. 100 is some weak sauce.Then work your way up and see what the car likes. If you're going to do drugs (nitrous), its always better to do more!
Old Aug 15, 2013 | 10:56 AM
^This guy lol. I like the way you do business!
Old Aug 15, 2013 | 03:46 PM
Slow LSX's Avatar
Missed this post, take out those TR6's and get NGK BF7EF should be part number 3346. You want a non projected tip plug. Go change them today and stop spraying on those TR6's.
Old Aug 15, 2013 | 04:46 PM
JDEP162's Avatar
right on^^^, brandon from nitrous outlet reccomended the for me, and they are what u want, they are the right tool for the job.
Old Aug 15, 2013 | 06:33 PM
Why wouldn't I want a projected tip plug?I've heard people argue both sides to this but haven't seen a reasonable excuse for either argument
Old Aug 15, 2013 | 08:57 PM
JDEP162's Avatar
i dont know the tech science behind the tip issue, i just go with what the experts say is best. imo brandon and dave at the outlet qualify.
Old Aug 15, 2013 | 09:54 PM
My6speedZ's Avatar
lots of reasons really. Heat, easily damaged during detonation are a few. A closed gap TR6 on a stock compression and 100 shot would be acceptable IMO but any higher or larger and go to a colder non-projected plug. Just my .02
Check these out:
https://ls1tech.com/forums/nitrous-o...tip-plugs.html
http://www.carcraft.com/techarticles/spark_plugs_tips/
http://www.carcraft.com/techarticles/spark_plug_tuning/
Old Aug 15, 2013 | 10:20 PM
I would agree with you on that
Old Aug 15, 2013 | 10:27 PM
Check these out:
That's some good info. Much appreciated. From what I've read if I gp higher than 100 I will definitely change plugs. And when I do I'll read em so I can tell what's really going on in there.
Old Aug 15, 2013 | 11:31 PM
dannyz's Avatar
Please listen to 6 speed z.
He is very politely telling you to scrap the tr6 plugs and go with a NON PROJECTED plug.
I was carrying the torch for the tr6 plugs for quite a while, and even got into heated arguments with atv racer and a few others.
I was wrong, and they were right.
I did not damage my engine, but I was lucky.
Play it safe dood.
