LNC 2000 Timing Computer & window switch
Old Aug 25, 2013 | 01:58 PM
NOS LS1's Avatar
Default LNC 2000 Timing Computer & window switch
Heres my N20 set up... Im pulling 5 degrees of timing only when the Nitrous Activation switch is armed. 100 shot. Window switch turns the nitrous on @ 2800 rpm & off at 5800 rpm before the factory fuel cutoff. My 404 ci Nitrous stroker motor pulls like a 500 ci. Big Block. Installing an innovate wideband air/fuel ratio sensor/Gage next week. Works great !
Attached Thumbnails LNC 2000 Timing Computer & window switch-002.jpg   LNC 2000 Timing Computer & window switch-005.jpg
Old Aug 25, 2013 | 05:45 PM
JDEP162's Avatar
nice, clean
Old Aug 26, 2013 | 10:04 AM
JDEP162's Avatar
also, looked for a while into the gauges on cowl like u have, any more pics of those, do u like them there?
Old Aug 26, 2013 | 01:31 PM
dekan513's Avatar
good looking ride, i love the lnc 2000. i use it with a nos launcher tho.
Old Aug 26, 2013 | 03:48 PM
HCI2000SS's Avatar
Very nice!
Old Aug 26, 2013 | 10:13 PM
KTK Z28's Avatar
Very nice. I love my LNC as well. It works like a charm. Also, very easy to install.
Old Aug 26, 2013 | 11:22 PM
NOS LS1's Avatar
Yes i like my gages on the cowl location. Later on the gages will be covered with a 4" cowl induction hood.
This is an ideal location. You can monitor your N20 & Fuel pressure while you make a pass. Gages are just a couple inches away from your line of sight. Monitoring the fuel pressure at full throttle while on the bottle will tell you if you have enough fuel pressure at WOT while on the bottle. Nano system is going in next so i can have stable N20 pressure & monitor that.
Attached Thumbnails LNC 2000 Timing Computer & window switch-nitrous-gauges-047.jpg   LNC 2000 Timing Computer & window switch-nitrous-gauges-049.jpg   LNC 2000 Timing Computer & window switch-nitrous-gauges-055.jpg
Old Aug 27, 2013 | 10:22 PM
JDEP162's Avatar
awsome thanks for the pics. ive been debating this for sometime. good looking setup
