Need Help w/ NX Wet Kit Install **Update**
Old Feb 11, 2003 | 08:14 PM
unit213's Avatar
Administrator
Default Re: Need Help w/ NX Wet Kit Install **Update**
Got the jets and the nossle. Getting the filled N2O bottle tomorrow. Will be spraying by the weekend. Dyno number should be interesting. I'll post the graph.
Old Feb 11, 2003 | 09:53 PM
Sears's Avatar
!Dial-up Director
I guess it's better late then never but the full instruction manual is in pdf format of NX's website, but it sounds like you are good to go.
Josh you can run the bottle line through the whole in the firewall behind the PCM on the passenger side, that is where I have mine.
Old Feb 12, 2003 | 01:54 PM
unit213's Avatar
Administrator
Actually Justin, I still have a few questions regarding wiring of the switches. I'll check out NX's webpage. Thanks for the tip!
Old Feb 12, 2003 | 04:08 PM
N.Y. LS1's Avatar
my page
There are a couple of pics of my install there. The solenoids pics are kinda dark for now b/c I haven't had time to mess with them.
The Guy in MY 99TA - question for you?
I was looking at your pictures, how did you get the nozzle so far into the bellows? Did you use the nozzle adapter? When I put my nozzle into the adapter, it does not go as far as yours does in your pictures. Can you tell me what you did?
Thanks, Jay
Old Feb 12, 2003 | 04:15 PM
unit213's Avatar
Administrator
edit: answered my own question.
<small>[ February 13, 2003, 07:34 AM: Message edited by: camaro_ls1 ]</small>
