NX Direct Port Install Update
Old Jan 31, 2003 | 09:21 PM
Reckless's Avatar
Super Moderator
Default NX Direct Port Install Update
Got the nozzles instaled today:
www.cofba.org/users/reckless/dp.html
www.cofba.org/users/reckless/dp_fuel.html
More work to do on Saturday!
Old Jan 31, 2003 | 10:03 PM
BADZ's Avatar
Moderator
Default Re: NX Direct Port Install Update
Very nice, keep up the good work!!!!! <img border="0" title="" alt="[Cool]" src="gr_images/icons/cool.gif" />
Old Feb 1, 2003 | 09:23 PM
Reckless's Avatar
Super Moderator
Hit a snag just as I was finishing up the intake tonight:
<img src="http://www.cofba.org/users/reckless/awecrap.jpg" alt=" - " />
Todd
Old Feb 1, 2003 | 09:28 PM
xaon's Avatar
doh! That sucks.
Old Feb 1, 2003 | 10:34 PM
justin sutton's Avatar
That would be easy to get out with an easeout.
Old Feb 1, 2003 | 11:36 PM
bo0oost's Avatar
Reckless - Good thing that happened BEFORE it was on your car, and you were spraying <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
Old Feb 2, 2003 | 03:29 PM
Country Boy's Avatar
Senior Member
Is that going to clear the cowl? It looks pretty tall since the original fuel rails are close..
Looks good though! <img border="0" alt="[cheers]" title="" src="graemlins/gr_cheers.gif" />
Old Feb 3, 2003 | 12:53 AM
35th SS's Avatar
nice work Todd.you da man. <img border="0" alt="[worship]" title="" src="graemlins/gr_hail.gif" />
Old Feb 3, 2003 | 07:48 AM
Reckless's Avatar
Super Moderator
Got it set in there yeterday. Fits fine with about an inch or two to spare <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" />
More pics to come!
Todd
Old Feb 3, 2003 | 01:30 PM
Reckless's Avatar
Super Moderator
They come installed into the nozzles from NX with some kind of sealant. I already broke off an easy out in there. I dropped it off at lunch at my local machine shop to see if they can remove it. If not, I guess I'll be buying a new nozzle <img border="0" title="" alt="[Frown]" src="gr_sad.gif" />
Todd
Old Feb 3, 2003 | 03:37 PM
Jim98WS6's Avatar
Very nice Todd.
Old Feb 3, 2003 | 03:47 PM
DJ's Avatar
DJ
that looks bad ****.
Great job dude.
Old Feb 3, 2003 | 08:17 PM
Reckless's Avatar
Super Moderator
Thanks for the compliments guys. This is a lot of work. More work than it was to install my turbo kit for sure. Mainly because everything has to be fabricated.
The broken nozzle could not be fixed, so I had to order a new one from Nitro Dave, but things are coming along!
http://www.cofba.org/users/reckless/nx20.jpg
http://www.cofba.org/users/reckless/nx21.jpg
<img src="http://www.cofba.org/users/reckless/nx22.jpg" alt=" - " />
Todd
<small>[ February 04, 2003, 08:11 AM: Message edited by: Reckless ]</small>
Old Feb 3, 2003 | 11:07 PM
xaon's Avatar
links didn't work for me. Perhaps they were:
Also, If one were to fab up a direct port setup on a composite intake, would it still be the same process in setting up the nozzles? Drill, tap, then seal with teflon paste?
Old Feb 4, 2003 | 12:33 AM
Louis's Avatar
Todd, do the NX nozzles come with those installed? If yes, Im assuming this happened when you were installing the line from the main rail to the nozzle. Just a faulty part <img border="0" alt="[bang head]" title="" src="graemlins/gr_banghead.gif" />
Nice work <img border="0" alt="[cheers]" title="" src="graemlins/gr_cheers.gif" />
Louis
Old Feb 4, 2003 | 12:41 AM
Dave95Formula's Avatar
Todd,
I have the NX 80000-EFI kit I am installing on my LT1. I am using the distribution block at this point, but I have a question for you.
The EFI kit is designed for 40psi of fuel pressure and you are using a Holley Pump rated at much lower psi. Are you changing the jetting on the fuel side? If so, would you mind sharing the jetting? Did you call NX and just get the carb/low pressure fuel jettings?
Thanks,
Dave
Old Feb 4, 2003 | 12:53 AM
KTamez's Avatar
Actually that is a common failure, and stems from not using a 3/8" wrench on the fitting in the nozzle when taking the B-Nut or fitting on and off the nozzle. Relatively inexpensive part, (Under $10) though that one looks like its gonna be fun to remove. <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" />
I've removed my share of broken nozzle fittings. <img border="0" title="" alt="[Embarrassed]" src="gr_emb.gif" />
Old Feb 4, 2003 | 08:10 AM
Reckless's Avatar
Super Moderator
xaon...thanks....I was pretty tired when I posted last night.
Dave....I called NX after talking with Sean Barnes (BadHabitBird). Sean runs the same setup at 9psi FP.
I have the revised jetting at home and will post it later today for you.
Todd
Old Feb 4, 2003 | 08:53 AM
Thanks,
I would appreciate it, I am almost definitely switching to a low-pressure setup myself. I had just got a pretty good deal on the EFI kit to begin with.
Dave
Old Feb 4, 2003 | 10:32 AM
ElkyRacer's Avatar
Todd, in that first picture of all the kit in the packages, does that direct port kit come with a big single distibution block? Im supposing you arent using this because you have the rails right? Can you possibly send me a picture of that block?
Thanks.
Kyle
