lnc 2000 mounting
Old Nov 26, 2013 | 06:38 PM
sinisterC4's Avatar
Default lnc 2000 mounting
Been looking for places to mount it. Didn't want to put it under the hood. Sorta stretched the wires out and think I could run it into the glove box on a C5. Just wondered if anyone has depinned one and done this?
Old Nov 26, 2013 | 06:45 PM
HCI2000SS's Avatar
I put mine under the hood, on top of the passenger side fenderwell
Old Nov 26, 2013 | 07:50 PM
sinisterC4's Avatar
That's probably where I'll end up putting it. Just had to ask.
Old Nov 27, 2013 | 09:10 AM
scantone1's Avatar
I cut them spliced them back together with about 2' of wire. Put it inside in my glove box.
Old Nov 28, 2013 | 08:50 PM
the404man's Avatar
Can you use this LNC-2000 with a 2004 chevy 2500HD LQ4 VCM and retain everything stock minus the timing retard and of course the nitrous ? ... SORRY nvm i should have just did a little more study, i found my answer .. i searched the last two days couldn't find the answer, then right after i asked here, ha i found the answer. Peace
Old Nov 28, 2013 | 10:27 PM
mcshocks's Avatar
Im in the same boat on my C5, Im thinking it might fit under the footwell area and MAYBE the connectors will fit through the grommet.
Old Nov 29, 2013 | 10:41 AM
igtabg1's Avatar
They wouldn't fit for me ... I used vector and attached it on the side if the fuse box...
Old Nov 30, 2013 | 07:48 AM
sinisterC4's Avatar
I did find this, last post says could make noise. Just going to mount it around fuse box and be done with it.
https://ls1tech.com/forums/nitrous-o...post-pics.html
Old Nov 30, 2013 | 11:58 AM
scantone1's Avatar
Think they have to say things like that. You can get noise from anything in the car. I personalty haven't had an issue. Also regarding the splicing of the wires as long as its done correct its not going to cause squat for resistance. Now do it wrong or cheaply ya sure it could. As for now mine works great and is located inside the glove box. But dont get me wrong it was a pain in the *** splicing everything but I am an Electrician so I have all the proper tools.
Old Dec 2, 2013 | 11:05 PM
JDEP162's Avatar
i did the passenger shock tower as well, never had any noise interference. i did buy msd wires at the suggestion of lingenfelter to avoid rfi interference.
